KW V3 Sedan Suspension Installed On A Wagon!.....Sort of.
Yesterday I finally got around to putting everything in. The fronts went in without a hitch - There are tons of write ups about strut replacement, so I dont think it needs to be laid out. After transferring the rubber isolators and top hats, everything bolted up without issue - even the plastic guide that hold the brake lines and speed sensors. The rear shocks however, are about five inches too long. This was great news to receive after battling the rear interior pieces to gain access to the top top shock mounts that are hidden under EVERYTHING. I reached back out to KW to see if another application may fit, or if they will make me something custom to match the front. Worst case scenario, I will install some of the Bilstein B6 replacements.
All in all, I have to say that the ride is drastically improved, and it was worth all the hassle. Car is off to alignment, holler if you have any questions, or if you want to buy the rear shocks, springs and perches for your sedan!
V3 length too please, if you still keep the measurement.
I want to compare with my original SACHS or Bilstein B4 , I am a non air-spring car.
If the difference is like your photo for V3 vs you rear damper at 5", there is a possibility the V3 itself is also too tall/long by mistake.
5" difference is just way too much if we assume V3 length as normal sedan with regular spring.
Loosing 5" of suspension vertical play on an air-spring vs a from steel spring ....sounds really a lot.
The stock wagon shocks are roughly 16.5 inches long un-compressed, while the KWs are about 22 inches. I assume the sedan has a taller wheel tub, since Mercedes was concerned about getting the rear floor flat in the wagon.
https://benzworks.com/
(714) 845-3431
(714) 845-3431
Keep up the good work. Subbed to witness the epic finale with the rear shocks.
Here is the part that I ordered for the top mounts of the new shocks:
https://www.fcpeuro.com/products/mer...glk350-802-516
(I dont want to remove rear air and I want to suspension mode changing by original button/system )
