Current main odometer reading is 1609343 km?
Hi, a reading of 1609343 km was shown in "Current Main Odometer Reading" (see pic), is the iCarsoft faulty or other problems?
The scanner is MB v3, and the path is:
1. Select - Control Unit
2. Select - EZS Electronic Ignition Lock (N73)
3. Select - View Data
4. Select - Last Stored Main Odometer Reading
Any ideas or advice is appreciated. Thanks.
pierrejoliat (05-18-2022)
This way, if a young guy need to manipulate the mileage into the IC, will set this 1,6mil value in EZS and after that the IC will accept any value.
Normally, the system always choose the greatest value between IC and EZS, so this solution is very simple if needed. Is like a bug of EZS.
Also, the 1,6mil can be just a mistake reading of the Diag system.
At exactly this value the EZS will stop synchronise with the Instrument Cluster.
Could someone have a iCarsoft please help?
pierrejoliat (05-19-2022)
Received 1,092 Likes
12 E350 4Matic 13 E350 4Matic AMG Sport
Ok, mine, on my '12 is spot on to the odometer reading, I don't see a way to change it with my Icarsoft 2. I do the updates once a year though, at a friends with a PC so did the update in February, I'm on Apple.
I will scan the '13 when it gets home.
Also, interesting update, when my wife got home with the '13, I scanned that too, IC and EZS were off by 3.2 miles! That is exactly the distance home from where she works! WTF? Maybe it updated her drive to school, but did not update for the ride home? I will check again later to see if it has "synced up" certainly not off by your amount, but off none the less, weird.
Senecat (05-20-2022)
