Headlight covers pre-facelift
He dremeled it, something I just not sure can do. I mean I can use a dremel, but will the new lens stick back to the old surface?
. It sucks that Mercedes uses a non-common method of sealing the headlights, but that's Germans for you
I tried MANY things - heat\ and cutting it - by the time you apply enough heat you are also melting the lenses too.
This is not the usual sealant as someone else mentions - MB used some other glue?
Cutting was almost impossible\impractical - I tried dermal and heat\prying it apart with no luck.
If anyone has any good ideas and wants me to try anything i can pretty much do anything as I don't care too much about the unit. I just gave up figuring not work the risk to my current units...
(short of melting in my oven LOL)
Hello!
I dremeled around the lip that goes into the headlight housing channel where all the permaseal (black goo) lives.
There is a chemical solution that you can buy and use a syringe to inject it around the lens channel to soften the permaseal and remove the lens without having to cut it and leave part of it in the channel. I believe it's called Permatrator and it's made by Morimoto. That might be a lot more work than the Dremel method but it would be cleaner.
Having said that, I'm on year 4 of using the GE bathroom sealant to glue everything back up and it held up just fine. I've been through massive rain storms, -40F weather multiple times with 0 issues. From the outside you can't tell the kind of butchery I've performed, you'd have to take the headlight out to notice it and even then it doesn't look bad.
I'll look for more pictures when I have some more time but it should be obvious where you need to dremel to get the lens out if you decide to go that route.
https://www.ebay.com/itm/35344717490...3ABFBMrL3N4Lhg
Which is it? I'd love to replace one of mine. A new headlight is $225.
