New 2011 Mercedes-Benz E350 Owner *NEED TIPS*
don’t know if that’s something I should look into thanks for all the tips and info thank u
ALL fluids, brakes, filters, plugs, mounts, sensors, belt, tensioners, VVT, PCV, batteries, radars, ...
These cars tend to be predictable with regular care.
4x solenoid adjusters : leak oil in ECU harness
4x position sensors : leak oil in ECU harness
2x timing chain tensioners: internal pressure leak
2x missing check valves: internal bleed
(4x variable timing gears : worned out lock pin)
It grows from cheap to expensive:
Phase I: Maintenance parts ($$$) @60kMi
Phase II: Repair worn VVT gears ($$$$) @150kMi
Your mileage may vary with driving style 😊
Which check valves are you referring to, CaliBenzDriver? You've piqued my curiosity. For the timing gears, Febi makes them and they're priced around 250 each. Still not cheap, but much easier to swallow.
Like others said, just the usual engine maintenance items are really required. Belts, pulleys, fluids, water pump (but not yet for you, I'm betting), that sort of thing. The PCV system probably isn't a bad idea as well.
The rear diff fluid is easy to change but the front (if you have 4matic) is trickier. It has a drain plug but no fill. If you remove the alternator you'll have access to the breather cap on top. Pull that off and you'll have a spot to pour in new fluid.
Look for fluid leaks. More than likely your oil cooler will need new gaskets soon if not already, and the o-ring between the power steering pump and its reservoir is another common leak point. The front diff will likely need to be resealed at some point which is not cheap or easy. Just like the rear crank seal, wait until it gets bad enough to warrant.
If/when the engine starts starts transmitting too much vibration to the car you'll need new engine mounts, which are also not easy. The transmission mount on the other hand is very easy to change.
Definitely change the transmission fluid, and use the kit you linked to. More than likely yours is using the red fluid, but do some double checking to make sure it's not using the blue fluid by chance. They're incompatible and IIRC 2011 was around when they started changing over.
Post back if there's anything you're not sure of!
> Front lower control arms are good to swap when bushings befome sloppy. Driver side stabilizer bar bushing + links become noisy.
> A maintenance kit with serpentine drive belt, tensioner and both plastic idlers are good to stay ahead of to spare your water pump and alternator bearings.
> Simple cabin blower filter replacement prevents from burning the speed regulator thermal fuse. In turn cleaner air helps spare the dedicated fan/filter cooling the hot head units ($$$$). Well worth doing on (50kMi) schedule.
Once you know... the game is to try to cut down on overgrown surprises
Which check valves are you referring to @CaliBenzDriver ?
In M276 MB improved the engine with 3 chains, oil pump and separate camshaft banks. They machined oil passages but carefully left out of the check valves that hold oil to prevent it from draining.
When engine is started there is no chain tension because these tensioners are plain non-ratcheting basic spring rod.
The tensioners soly rely on oil pressure to keep the internal spring from bouncing with camshafts back forces.
The tensioners shaft and bore are machined loose so the seal serves as bearing guide unti it is worned through and leaks pressure.
With lack of oil pressure, the lock pin in the VVT gears normally prevent the uncontrolled back and forth camshaft motion. The soft steel surfaces are not heat untreated so the pin wears itself loose going in/out frequently. That's when the startup rattle gets predictively loud and engine harder to start.
The rattle is one thing but when the camshafts are free to rock back and forth the valves timing varies +/- 10°. The whole engine will vibrate increasingly until the ECU is no longer able to manage VVT position with solenoids/sensors and pop codes.
I'm on number 2 ( I buy used...so I'm "that guy"l
That being said, of all the cool cars ive owned...these are just different. Purely a pleasure to drive every day.
This site has helped me immensely and there's a wealth of knowledge.
Drive her until the wheels fall off.. (don't worry, they won't. It's not a BMW)
