Sponsored by: CARiD
Coolant leak
Old Jul 12, 2022 | 09:02 AM
S. Madman's Avatar
2012 E550 sedan 2019 E63 Wagon
Coolant leak
Well I knew it was a matter of time, but it looks like the leak that has been on SUV's is finally catching up to us.
Out to the dealer it goes.....
Under the thermostat.
Old Jul 20, 2022 | 05:24 PM
S. Madman's Avatar
Well an update on this, MB dealer, and Eurocharged want $3k+ to swap lines. This means the car is getting parked, and another car will be driven.
Inflation just tripled the price in labor, for $100 dollars worth of parts SMH.
If I don't part out the car first, I may see you guys only in the W213 forums for a while.
Old Jul 20, 2022 | 05:59 PM
Couch67's Avatar
E550 Coupe
ouch, sorry to hear that. Yes, while I love driving this car, I'm waiting for that time where something comes up that I can't fix and its a four figure repair bill. I hope that time is still a long ways away...
Old Jul 20, 2022 | 10:27 PM
Arrie's Avatar
Swap what lines for $3k+?
Old Jul 21, 2022 | 12:35 AM
S. Madman's Avatar
Sorry swap the 2 turbo coolant lines.
Old Jul 21, 2022 | 12:47 AM
S-Prihadi's Avatar
ohhh, the leak comes from the turbo coolant lines... damn.
In your M278 these coolants lines are like below ?
https://www.ebay.com/itm/25549359962...8AAOSwIMJiXHze
If so, that means the plastic portion is the broken/leaky one...yes ?
Probably the same engine as yours ?
Old Jul 21, 2022 | 09:01 AM
pierrejoliat's Avatar
24 GLS580 '23 E450 4matic 12 E350 4Matic
Wow, that sucks, I worry about repairs like this also, I tell my wife we need a new car and she says "I like this one" , this process usually goes on for three years or until a repair like this comes up, but of course by then I have to fix it first.
I believe they have improved radiator stop-leak as time has passed, I don't think it clogs things up as bad as it used to, much as I hate to suggest that, one must sadly do a realistic cost benefit analysis. I have a suggestion, my daughter was looking at a huge repair bill for a similar issue, she ended up taking it to a local technical high school, it worked out well and she paid 25% of the dealer estimate.
Old Jul 21, 2022 | 05:35 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
ditch plastics
mixed plastic + metal conduits
Can you patch a section of rubber coolant hose to replace the brital plastic section? It looks like there is a 1" overlap at each end for a tight grab.
metal + rubber coolant line 👍
Old Jul 21, 2022 | 07:32 PM
chassis's Avatar
2017 GLE350 4MATIC
I can see how a dealer would charge $$ for this because lots of parts need to be removed to access the coolant pipes.
On the other hand, "it's just a small pipe". I see this as DIY-able, acknowledging alot of time is involved.
Regarding a repair to the pipe, this would be temporary at best, I would DIY replace it if this was my vehicle.
Old Jul 21, 2022 | 09:07 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
On the other hand, "it's just a small pipe". I see this as DIY-able, acknowledging a lot of time is involved.
It is definitely not rocket science, nor need for special tolerances/measuring. But the ability to rebuild the puzzle afterward.
What do you think will be the weak point of patching with a hose? Pressure range? Thermal wear on the hose? Certainly, it already is a maintenance item, i.e. to be replaced after a certain mileage. I see it possible as a quick recurrent cheap fix. Say replace the hose segment every other oil change (along with the O-ring anyways).
Old Jul 21, 2022 | 09:13 PM
JCM_MB's Avatar
I understand the need to reduce the "carbon footprint" of every vehicle out there; however, I would love to understand why use plastic on that item. It is already solid metal the rest of the way. Thermal expansion/dilatation because of the hot temperature at the other end (turbo side)? If so, I think rubber has better thermal wear characteristics than plastic, but MB's engineers know better than me
=== Update ===
For references to plastic and rubber under high temperatures
https://www.martins-rubber.co.uk/blo...ber-materials/
https://www.craftechind.com/heat-resistant-plastics/
Old Jul 21, 2022 | 09:15 PM
is polyethylene the new EPDM ?
I am not a hose guy... but it seems the skinny plastic tube is the cheapest possible version of rubber with reinforced walls.
Perhaps plastic is able to take more heat for a while than heater core/radiator flexible hose
Old Jul 21, 2022 | 09:24 PM
cost...
plastic does not need to be layered with reinforcement nylon thread.
In homes, they use a plastic serpentine hose to heat cold floors on East coast. It has a layer of aluminum pipe embedded within the plastic tubing.
It makes sense to have a flexible insert of rubber to allow for expension and alignment of the metal pipes. Once plastic gets hard, stress relief cracks develop
Old Jul 21, 2022 | 09:50 PM
chassis's Avatar
2017 GLE350 4MATIC
It's not clear the root cause of the leak has been definitively identified. One possibility is a cracked end where the part is plastic injection molded. Not repairable. The other part is the hose-metal pipe juncture that looks fused. Maybe a hose clamp could work. Or an abraded plastic or rubber tube has worn a hole. Not sure the best repair for that.
I wouldn't waste time with a repair. Replace the leaking tube and do it right.
Old Jul 21, 2022 | 11:20 PM
S-Prihadi's Avatar
This is an engine OUT view for coolant lines replacement
I just read this unique information on M278. Some have separate aftercooler coolant recovery bottle some doesn't.
https://www.benzworld.org/threads/m2...rvoir.3081144/
So when troubleshooting coolant leak, observe this information accordingly if cross sharing of cooling lines exist.
If only a single coolant recovery bottle....it can only mean sharing of cooling facility between aftercooler and engine.
For M276 3.0 Turbo it is easy.
Aftercooler is totally a stand alone coolant circuit with its own coolant reservoir bottle , so leak here has nothing to do with engine cooling.
Old Jul 22, 2022 | 08:19 AM
JCM_MB's Avatar
Wow.. Just a five-minute job in a few steps :
1 - Disconnect the engine from the surrounding
2 - Lower the sub-frame+engine assembly
3 - Replace cooling lines
4 - Push-up the sub-frame+engine assembly back
5 - Reconnect the engine
6 - Refill fluids
7 - Notify the customer in the waiting area.
I assume the engine out procedure is standard, and it is based on the customer can afford it.
Old Jul 22, 2022 | 07:12 PM
S. Madman's Avatar
6 - Refill fluids
5 minute job instant=$3000k labor.
Nah, this is becoming normal, and someone is bound to make a better part. All aluminum would be best. Just going to wait until enough S550's and CLS550's go thru this, and MB or the aftermarket will take action. Not going to replace crap with the same crap.
@S-prihadi yes those are the lines.
Old Jul 22, 2022 | 09:46 PM
S-Prihadi's Avatar
Well.... 2012 to now is 10 years. A scarry age for plastic/rubber on our engines potentialy breaking down.
The very same reason I compiled my 10 year rejunevation plan. Sell car at 10 years old or do the "expensive" list and keep the car to at least 15 years of age. June 2024 is E400 10th year.
What I seen on M278.
Soon there will be issues on these :
01. Heater plastic pipe from rear of engine to firewall to heater core of HVAC.
Y16/2 Heating system shutoff valve.
02. Thermostat and its plastic housing. Same as M157
https://www.ebay.com/itm/353377977026
I think being turbocharged and if we drive agressive, we aged these plastic/rubber faster than gentle drivers on non turbocharged engines.
Fun and heavy throttle foot has its cost
If engine out is what needed to be done and if the car is intended to be kept to say 15 years old, start looking at every plastic/rubber ( should be plenty ) which handle coolant or oil and replace them all.
Engine mounts on M278 seems a pain to remove, so while engine out, replace them.
Old Jul 23, 2022 | 07:03 PM
diesel_dan's Avatar
2013 E550 sedan
@S. Madman How many miles on your car? how aggressively do you drive? Does anyone know if this is tending to be an age or heat cycle (or just heat) or miles issue? Disturbing for sure... We've been popping the hood on ours for some time now and letting the engine bay cool with hood up when we get home...
Old Jul 23, 2022 | 11:12 PM
Quint22's Avatar
Veteran: Navy
2014 Cummins, 2014 E250 Bluetec
My 14 cummins is same way, in 14 they went to several plastic parts mixed in with the rubber hoses and what not. They crack on some of them. Even worse sometimes they hold till heated up and then leak but finding the actual culprit is a pain because they seal back up when cold atleast on the truck. Imagine these are the same way. The hard plastic like anything else plastic eventually fails. For my truck there are some aftermarket aluminum pieces that replace the plastic. That would be the best route to go here if they were made.
Someone with some machining skills could make a few bucks for sure.
Old Jul 24, 2022 | 02:00 AM
S-Prihadi's Avatar
Let me tell you a story of my 2011 Ford Fiesta 1.6L with PowerSHI-ET tranny the manual double clutch cheapo tranny but automated with solenoids and Class Action law suit material indeed.
One day the coolant hose from engine to heater core had a tear.
I lost coolant and managed to avoid cylinder head warping overheat by some luck.
Why I did not call a tow truck was because the area I was at is not safe, so I keep filling the reservoir with water at intervals and managed to drive home.
The stupid Fiesta has no coolant temp gauge, only OVERHEAT warning when overheat occured.
The overheat was so bad, even my low engine oil pressure lights up due to thinning of the oil I think. At least Fiesta has Low Oil Pressure warning unlike my MB
Anyway. I replaced every damn plastic and hoses on the car, including a new radiator which is plastic on its sides.
Some hoses plastic ones when removed, the crumbled down like dust...insane.
All brake hoses also replaced.
I paid a lot, US$3.5K to replaced those plastic/rubber worries and do some repair on the tranny shift bearing
The car used value was only US$4.5K in 2021 when all these occured.
I wanted to keep it for 5 more years....so I thought.
When all good, the ABS light pops out 1,000KM later. This ABS module locally caused US$800 or so.
I got sick of the car and I sold it off.
Lucky new owner, he only needs to buy ABS module and the rest of the car and its plastic/rubber worries are gone.
I envy quality marine diesel engines, no plastic parts.
Yes, hoses we change at 10 years, but very few hoses compared to a car engine which has lots of "accesories".
Plastic and rubber failing is a matter of WHEN and not IF.
M278 being bigger in size is more complex than my M276.
Seeing my turbo coolant hose is not designed as stupid as M278, there is still a plastic end but not at engine block....LOL.
Item 40 is where plastic end is used.
I am 2 years away to the car 10th Bday and I am already have the rejuvenation plan/list.
I think US$10K will be exceeded in parts and labor, and the E400 by 10th year value would worth at best US$24,000 in 2024. Now it is still worth true market wise approx US$33K but the tax book
charged me road tax based on insane US$53K x 2.1% per year.
If I go thru with my keep for at least 15 years PLAN, the only reason is because cars are downsizing in engine capacity and I want minimum 3 liter. Indonesia ADDITIONAL luxury tax is based on engine displacement.
I can't afford the E63 W213 AMG big engine version, in fact even if I have the money, I wont buy engine with freaking turbos at the hot middle of the V bank ( M176 / M177/ M178 ), no way for my climate and traffic jam.
Old Jul 24, 2022 | 10:54 AM
S. Madman's Avatar
116k I open the hood everyday I drive it. Half throttle is the most I go, since it has plenty of power to pass. Must of the time 70mph on the highway. This recent heatwave in FL killed the hose off.
Old Jul 24, 2022 | 11:57 AM
diesel_dan's Avatar
2013 E550 sedan
Thanks for filling in those details - unfortunately not reassuring for us: I drive like your screen name! Was hoping the hood open thing would be our saving grace... We are still under 40K miles on the car, so less heat cycles, if that is a factor. I need to see if the other applications of our engine are failing with miles or just time - have you looked into that at all?
Old Jul 24, 2022 | 04:39 PM
JCM_MB's Avatar
Hope you keep it in the garage, sister's W211 windshield just cracked parking outside the house. Sure it had a rock chip, but it had been there for a while.
Old Jul 24, 2022 | 05:50 PM
S. Madman's Avatar
Only one of my cars (infiniti G37 sedan) sleeps outside. All the other ones sleep inside. Funny enough it's been the most reliable I have ever owned.
