Rattling steering wheel
Here's a video of the sound, you need to have the speakers up to be able to hear it. It's more pronounced in the end of the vid.
No but really, do you have access to an independent MB shop versus the dealer? They are only going to tell youthe most expensive option for repairs. Hell, it could be a loose piece of debris bouncing around for all we/you know.
GL to you.
Yeah I have some independent work shops here but it's always a hassle to bring the car over and taking a rental etc. So if someone has had this same issue I could fix it my self.
Nothing is impossible with the best cars, I hardly believe a busted wheel vibrator would produce that sort of soft chirp. Try to disable "Lane Assist
Check the door to OBD2 port is closed (below dash)
Is the tiny fan circulating air over temperature sensor ok or noisy? It's near where you have the camera...
Set HVAC to OFF to disable any air vent flow
Can you extend your steering column to different coordinates. This will pull on internal harness.
Perhaps steering wheel airbag module is not pushed all the way in against its spring catches?
One of the beautiful dashboard trim pieces could rubbing ...
I am going to guess there could be something worned out. Can you feel any abnormal freeplay in your 2004 steering column? Not so much, correct?
>> On the other end it could also be something loose vibrating steering through the rack, tie rods, warped disc, control arm bushings, tight caliper, warped rim can vibrate an ok column that would otherwise be quiet.
I mention that because this is a "speed sensitive" issue...
MY'04... by now you could also be dealing with the combination of a loose steering vibrated by the feedback through the column...
