Sponsored by: CARiD
HK Logic 7 amp capacitor fried
Old Jul 25, 2022 | 05:49 PM
anglil22's Avatar
2016 e350 W212
Hello,
My HK amp has a fried capacitor and I can't seem to find a match to replace. I have attached photos, hoping someone could give me some guidance. Thank you in advance.
Old Jul 25, 2022 | 06:45 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
mixed up
A: Power Amps B: caps
Take a good picture of the parts marking you are interested in replacing... or let's just say both A + B.This will help identify what parts were used.
Old Jul 25, 2022 | 06:51 PM
anglil22's Avatar
2016 e350 W212
Thanks for the reply. Based on your markings its A. I have attached another pic showing the fried circuit area with an arrow.
Old Jul 25, 2022 | 07:43 PM
Cajun style 🤪
I see... one of the power amp chip took out part of its circuit traces
overheated traces (not yet 100% cooked)
Do you want fix that? 70% this can be done successfully because these amps are all similar... you can compare reference measurements with nearby circuit .
See the 2 little "ceramic caps" are like a signature next to this chip: likely Spk. outputs (not a power feed) because there are repeated pattern.
Beside one or more TDA chips + caps.
For everyone... this is why you don't want to push this OEM amplifier enclosed in the trunk left side with restricted air circulation.
Old Jul 25, 2022 | 07:47 PM
anglil22's Avatar
2016 e350 W212
Thanks, I would be interested in fixing this.
Old Jul 25, 2022 | 07:51 PM
forward
clean up the chip markings
> Time vs. Money:
Are you a quick learner?
Can solder micro-electronic right?
> Plan B:
Whats your budget to buy a donor amp
Old Jul 25, 2022 | 07:54 PM
anglil22's Avatar
2016 e350 W212
Yes, I am pretty good with a soldiering iron and can pick up things pretty quickly
Old Jul 25, 2022 | 08:01 PM
anglil22's Avatar
2016 e350 W212
I have replaced this amp, don't want to spend too much since it would essentially be a spare. I figured I would give it a shot to repair myself if possible.
Old Jul 25, 2022 | 08:06 PM
Amp markings
Read the markings off of your very own chip.
my HKL7 chip as sample (MY'14... Mfd'13)
It uses a different layout, so likely a different reference.
Old Jul 25, 2022 | 08:10 PM
fixing spare
What did you replace it with: Identical or aftermarket?
What was wrong with bad channel: SPK shorted near zero from overheated coil insulation? This forced the amp to drive power into a shorted load maximum current + heat
Old Jul 25, 2022 | 08:23 PM
anglil22's Avatar
2016 e350 W212
Easier said than done...LOL mine are not as clearly marked as yours.... I have attached a photo. Even with my readers on it is tough to make out the numbers. Yes, speaker shorted out. I replace it with identical since I upgraded my sound system and had to use the stock amp to integrate with an aftermarket.
Old Jul 25, 2022 | 08:35 PM
this is the designation marking
Do you read... "77B88ES" ?
You need to be sure!
Old Jul 25, 2022 | 08:36 PM
anglil22's Avatar
2016 e350 W212
Yes, that is what I read...
Old Jul 25, 2022 | 08:41 PM
ghost
that's the part you have to buy.
I dont find matches, double check markings with a magnifying lens
Old Jul 25, 2022 | 08:42 PM
anglil22's Avatar
2016 e350 W212
Thanks, yes I tried a quick search and came up empty. I'll zero in on the markings and take it from there. I appreciate all your help! I'll chime in if I find it.
Old Jul 25, 2022 | 11:20 PM
RWagz's Avatar
2022 X213 E 450 Wagon
I found a working one on ebay for $240. It might be difficult to find the integrated circuit being sold anywhere. You will likely need to get one from a dead donor.
Maybe you'll get lucky and find someone selling a dead one on ebay.
Old Jul 26, 2022 | 12:42 PM
anglil22's Avatar
2016 e350 W212
I saw that one. I'll keep poking around, as mentioned no rush. I was able to decipher the chip, picture attached. Unfortunately, haven't found one so far. Thanks again for your help!
Old Jul 26, 2022 | 01:02 PM
888... not lucky 🤪
that reference number looks like a short straw until a genius stops by with directions to the land of plenty...
Old Jul 26, 2022 | 07:55 PM
Senecat's Avatar
1983 Nissan Shltbox
ebay.
Old Jul 26, 2022 | 08:53 PM
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
that ST logo on the lower left of the last smallish picture is ST Microelectronics, https://www.st.com/content/st_com/en.html
that said, none of those numbers, with all sorts of variants, match any search, so its quite possible these are proprietary parts for Harman-Becker.
btw, surface mount soldering of chips like these is a lot trickier than regular soldering.
Old Jul 27, 2022 | 02:52 AM
BenzV12's Avatar
W212 FL
I didn't know those things could be burnt out
Old Jul 27, 2022 | 02:59 AM
specs say chips are foolproof
These chips being hard to toast, the circuit board Vias got overheated in the process
Old Jul 27, 2022 | 12:12 PM
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
Smd repair
Smd repair is a nice skill to pick up. I recently picked up a nice hot air rework station and tools for my pinball machines. This can not be fixed with just a soldering iron. You need hot air, iron with a needle tip and magnifying lamp and a flux pen.
Chips are in short supply for everything, not just new items. Some for my pinballs are not scheduled to be made for 12 months.
Make sure to try mouser or digikey. Digikey will have a reference if it’s available anywhere.
the cost of the smd rework station and you time and the chip make this not an economic winner. I only repair expensive or out of production items and it made the station worthwhile.
good luck. That little cap is easy to find and the numbers are on them. but the chip will require a deep dive….alibaba if no others found. If they have it, that’s all there is.
Old Jul 27, 2022 | 12:21 PM
Quint22's Avatar
Veteran: Navy
2014 Cummins, 2014 E250 Bluetec
Pointy iron and mag glass is what I used to repair smaller ones on a couple tablets. No hot air or flux pen. Granted I am not an electrician and if doing a bunch better ways but it is doable. I found some good instruction videos on doing it.
This is the soldering iron I picked up for doing the jobs
Amazon Amazon
It has performed pretty good for the random repairs I need it for.
Edit to add obviously good lighting, flux wick, tweezers, flux, basic soldering stuff required.
Old Jul 27, 2022 | 03:01 PM
anglil22's Avatar
2016 e350 W212
I have checked Moser and DigiKey and came up empty. Hopefully when chips become more readily available I will have some luck. Fortunately, not in a rush here.
Thanks to everyone for their help!
