Sponsored by: CARiD
Vibration on steering wheel when car is stopped
Old Jul 28, 2022 | 02:30 AM
keeepwalking's Avatar
w202, w212
Hi guys. My car is w212, E350 4matic, 2010 with 19 inch rims. When the car is completely stopped and I turn the steering wheel left or right there is a vibration in the steering wheel. The problem doesn't depend on whether the car is on "D", "N" or "R". When the car is moving even slowly the problem is not observed. Somebody with the same issue ? How this can be resolved?
Old Jul 28, 2022 | 02:41 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
steering
A/C compressor not running, right?
replace steering oil + serpentine kit
then pump regulator may be shot... new pump!
Old Jul 28, 2022 | 03:09 AM
w202, w212
A/C compressor is not running.
Old Jul 28, 2022 | 03:29 AM
vibrations vs. freeplay
The torque of the oversized wheels may have chewed on the old rack & pinion steering gear, bearings and tie rods. How is your steering freeplay: S-M-L ?
Old Jul 28, 2022 | 03:44 AM
w202, w212
What means S-M-L ?
Old Jul 28, 2022 | 04:11 AM
Small/Medium/Large:
What means S-M-L ?
Assessing your steering wheel freeplay:
  • none
  • a little
  • a lot
This is an indication of the rack & tie rods health.
(overlooking wheel bearings).
A worned out serpentine tensioner can do that well and keep everyone guessing what is causing the pump pressure to surge. I've had that
Old Jul 29, 2022 | 04:09 AM
w202, w212
There isn't a steering wheel freeplay.
Old Jul 29, 2022 | 02:25 PM
pump regulator 😜
Then you're good to run down this list one item at a time:
  1. belt tensioner kit
  2. steering pump and HP hose
  3. rack and pinion with alignt
Old Aug 5, 2022 | 03:18 AM
w202, w212
Hello, at the auto repair shop told me that this vibration comes from the friction of the tires when turning in place. It sounds reasonable because on some surfaces it's barely noticeable.
Old Aug 5, 2022 | 01:36 PM
full circle...
When the car is moving even slowly the problem is not observed....
We go back to the OP where you have the answer to your question:
"When the car is moving even slowly the problem is not observed".
Skill from non-power steering cars:
NOT steering the tires from L to R without moving at all remains a pretty good practice!
It strains the tire plys integrity, steering tie rods and rack bearings. The outcome is soft tires plus worned out steering looseness/freeplay.
Old Aug 6, 2022 | 09:55 AM
RA72825's Avatar
As the Doctor would say “ then stop doing that”.
Old Aug 8, 2022 | 02:26 AM
w202, w212
These are good advices
Old Jan 15, 2024 | 02:31 AM
w202, w212
I replaced the two engine mounts. No more vibrations in the steering wheel. It is so quiet in the car now, that you can't tell whether the engine is working.
Old Jan 15, 2024 | 02:37 AM
BenzV12's Avatar
W212 FL
Nice to see it was fixed . We had to replace in my W212s too besides tranny mounts
Happy Driving
Old Jan 15, 2024 | 03:57 AM
S-Prihadi's Avatar
To get vibration from engine mounts , up to steering wheel at idle in neutral....... your flexible engine mounts has long gone and its already hitting the engine mount housing.
Is the black rubber flap of engine mount has this friction markings and also the metal top part of the mount ?
