P0236 turbocharger/supercharger boost sensor a circuit range/performance Help!
Hi all
i just got a 2014 Mercedes E550 4matic and today i got an engine light when i looked up the fault code i got
i am a newbie here and not very sure what is wrong and where to look
any help would be very appreciated
thanks in advance
thanks in advance
biker349 (08-12-2022)
Received 4,553 Likes
On this W212 ............... there is M276 and M278 turbo thingy in discussion, still within 1st page .
Thank you for your reply but it wasn't mentioned in that thread anything related to this specific error I still need to go through everything mentioned there to understand if it is same problem but different names
But thank you again
But thank you again
You are using generic OBD2 scanner ...yes ?
Based on Xentry, but M276 3.0 turbo engine computer. Many DTC are the same for your M278 I am sure.
Go to https://mbworld.org/forums/e-class-w...code-list.html
Video no 2 of 5 for engine computer.
There are a few P0236xx
Basically this P0236xx DTC means, the turbo boost data is whacky/wrong/does-not make sense ,,,,,,,,,,,,,,,,,,
Thank you for all the info provided that actually helped a lot
Just for anyone having the same issue i found it was because of RaceChip which was installed by a previous owner he said it was not active but it looks like it was throwing some issues removing it solved the whole issue
Glad to hear you found the culprit.
Aha... so there is that dumb piggyback device called RaceChip.
https://www.racechip.com/downloads/E..._K2_ENG_V1.pdf
Sometimes I wonder, how easy people/consumer can believe this so called "TUNING", when what is being done is a sensor data cheating.
The piggyback intercept say a 10psi boost and cheat it, send it to engine computer and claimed as 8psi boost... so that engine computer will allow more boost.
The reasoning are all the same crap : Ohh OEM are always playing safe and not maximizing engine's potential yada yada, so we then maximize it
Lowering sensors reported values to cheat engine computer to allow more power is pure dumb at its finest.
The following 3 users liked this post by S-Prihadi:
hope my advice helped at least somebody loves there biturbo like I do with my E400 coupe
