Where to begin
please use this
copy paste this msg there and you'll recieve the info
https://benzninja.com/contact/
As far as my original issue. So I took off conductor plate and dropped in ultrasonic cleaner then finally was able to get car started. It also allowed me to actually clear what codes I had. Then of course when I go to take it down off ramps I guess the ism put a stop to that and I now have the following codes.
0778- pressure regulating valve 2 has an electrical fault.
2716- internal electrical test of component y38y for k3 clutch control solenoid valve has failed
2759- the pressure regulating valve of the torque converter lockup clutch has an electrical fault you up
C103 no can message was perceived from control unit n15-5 (electronic selector lever module control unit)
B210f00 circuit 30 has a malfunction
475600 no can message was received from control unit motor electronics
A3a813 The output for window heating has a malfunction. There's an open circuit
D19800 electronic ignition lock - communication with the ism has a malfunction
please God someone advise what to do.... currently loosing my mind
start by replacing the plate and testing the solenoid
so communication may reflect that...
The concensus is he does excellent remote miracles
Follow his lead ✌️
if you give me your vin number
