is my car possessed??
Hi all, yes, I believe my 2010 E350 is possessed.
Left the car at friend's driveway for about 2 months, started up fine, drives fine but, after a few minutes, the problem starts, lights on panel such as headlight, tire, break, fog light etc.. go on for a few seconds then turn off, also the AC, fan, radio, GPS turn off for a few seconds then turn on, vipers too. I have seen the clock also going backward. Car drives fine while all these are happening. If I turn the car off while these are happening, I wont be able to lock the car or start again for a while.
The main battery is over 7 years old, aux battery not sure how old. I have about 110k miles on the car.
Have you seen this phenomenon at all? is it my battery, some computer module or just possessed?
Thank you for any help.
The following 3 users liked this post by DeTh:
Yikes. The first thing I would do is disconnect both the main and aux batteries, charge them both, then reconnect them. It's free and easy. I've had a electrical gremlins due to weak batteries and had to have them both disconnected to reset the control modules (disconnecting individually did not resolve). You've gotten your money's worth out of the batteries so replace them ASAP and save yourself the headache and worry.
The following 3 users liked this post by up_too_late:
Last night, when I parked the car, it would not lock doors and I had to use the mechanical key, this morning, as if this is not the same car, started right up, lock/unlock doors. I am in Birmingham Alabama for another two weeks, only know pepboys around here so will take there today to change both batteries. MB dealer is a bit too far, unless you guys recommend me going to dealer, I rather not.
Received 4,449 Likes
Was all these after a big rain ?
How long have you owned this car ? I mean how well do you know the history of the car ?
CAN BUS junction connector ( like a distribution connector) being wet can also cause funny-funny weird things
VBaboli (09-02-2022)
yes, it was after the big rain but this car has been in big rains before. I had this car since 2014, has been good so far. The batteries are def old but where is that CAN BUS located, can I check it out myself to see if is wet?
W212 is the same, depending on which CAN BUS channels, its at the LEFT and RIGHT side.
Best start at driver side.
Leak developed and accumulate over time.
VBaboli (09-01-2022)
Did you attach a picture, it does not show.
Found some post here: CAN BUS TOPOLOGY - MBWorld.org Forums
A PDF was there including the details.
Lifted the floor mat and there it was, water there is no drain??? I am not in my home there is no shop vac here.
If I get the water drained somehow, I still need to dry things that I can not even reach. Which shop even does these things?
I youtube video is very detailed, I can not do that here away from home.
UPDATE: Driver side is dry for whatever reason, ripped the floor out on passenger side and took a round plastic out so the water drains, not sure why it was there to begin with, I may not put it back. Dried water as much as I could and left a 1500W blower heater there. Will see in a few hrs if get any better. I will still change the battery later today.
Received 1,585 Likes
2008 E350 (W211 @170K), 2012 ML350 (W166 @119K), 2014 E350 Sport (W212 @96K), 2015 ML350 (W166 @92K)
Check the roof drainage along the A-pillar, it must be clogged with leaves or dirt. Once the water stop running, it starts leaking into the cabin.
MB --> fish bowls when the drainage is not maintained/checked frequently.
Dry it as soon as you can, and as dry it can be; otherwise, you are bound for more damage (harness/pcb board corrosion) and $$$ along the line.
For the driver side,
1 - Open Front-SAM and not properly closed:
2 - Windshield replacement
3 - Incorrect positioning of the AC filter/AC AirBoxCover
Another video
, just mirror the image if you are in the US
Never seen that much water into a MB, but it happens
Hopefully, you get the point. Summary: do not leave your car exposed to the elements for long periods.
Another video
The following 2 users liked this post by juanmor40:
CaliBenzDriver (09-01-2022),
pierrejoliat (09-01-2022)
Received 3,404 Likes
2012 CLS63
Talk to a priest, maybe a roman catholic priest
The following 3 users liked this post by hyperion667:
pierrejoliat (09-02-2022)
I have heard of weak batteries causing weird problems but this one was beyond my imagination as well . You're on the right path hopefully you will get it sorted out .
May the force be with you
Usually low voltage will cause "No Com" or as if module is OFF.
OP unique condition is like a module receiveing weird instruction. I guess the water bridges a few modules at the CAN BUS junction bar/distributor, so some modules
get multiple command from other modules and born are new weird commands.... LOL
Here's some update, yesterday I spent many hours draining the water and drying the passenger side front and rear floor. Took the car our for a spin and also to replace the battery, all seems to be fine, no strange behavior, no sign of no exorcism is needed. I am leaving the floor covering up for a few days until the foam completely dries up. However, somewhere in the process, I managed to cut off the sound out of COMAND device, no sound out of radio, blu-tooth, GPS, nothing...
I traced back what I did and all connections seems to be in place. What could I have done to cut the sound??
Many thanks to everyone who helped me finding the issue.
For the driver side,https://youtu.be/KGVgr877lfg?t=1806
Another video https://www.youtube.com/watch?v=QAKmDkDxtBk, just mirror the image if you are in the US
Never seen that much water into a MB, but it happens https://www.youtube.com/watch?v=vC3v9gTj-XI
Did you check the wiring under the front passenger footwell, it is behind the carpet, metal shield. See this video for what I am referring to (ignore the filter change)
The following 3 users liked this post by juanmor40:
Glad to hear you are making progress, and you are nearly out of the woods.
Did you check the wiring under the front passenger footwell, it is behind the carpet, metal shield. See this video for what I am referring to (ignore the filter change) https://youtu.be/9QAiHp93Lw0?t=89 There is a ground point there as well.
passenger side under the carpet
In the picture, you see the blue connector and the orange wire disconnected. I need a wiring diagram now
CONFIRMED: The broken wire *is* the sound juice. I don't think can buy that connector, I am thinking to eliminate it altogether and patch the wires together.
Other than potential leak source/s Utube shows from
If that hose somehow loose and came off from HVAC plastic casing, it can be a water source into cabin.
Above is a rear view if we see HVAC complete housing from engine bay into interior
The following 3 users liked this post by S-Prihadi:
Should I not put them back?
took the plug pointing by black arrow out of the hole pointing by red arrow. There are two I had to take out to drain the water.
Better put them back, you do not want an open floor ready from water intrusion while driving.
Those holes are needed during manufacturing.
You have to keep them plugged for water protection during rain from road splash etc etc as explained by J40
VBaboli (09-04-2022)
