Sponsored by: CARiD
Need help tracing wiring issue
Old Sep 4, 2022 | 12:10 PM
pmnewcomb's Avatar
'14 E250 Bluetec, '99 E55 AMG, '90 300E
My drivers side DCU is not getting power. I checked fuse 39 and pin 8 of connector 3I on the rear SAM already. Both points in the rear have good voltage. Tried using ground in engine bay and power connector on DCU, still no good. Somewhere the positive wire is shorted to ground.
Old Sep 4, 2022 | 12:58 PM
konigstiger's Avatar
'71 Pinto
Pull lining to check harness/connectors you can also check harness passing through tubing (5).
File Type: pdf
Old Sep 13, 2022 | 01:30 PM
'71 Pinto
To add... f39, 3I rear SAM connection/pin 8, see attachments.
File Type: pdf
File Type: pdf
Old Sep 13, 2022 | 02:05 PM
pmnewcomb's Avatar
That's what I checked first using the ground point in the trunk. It shows good voltage from the fuse and the output pin into the harness. I also am having issue with the left headlight and marker light, so i'm hoping once I start tracing those faults I'll find the common point of failure.
Old Sep 13, 2022 | 05:09 PM
'71 Pinto
See attachments.
File Type: pdf
File Type: pdf
Old Sep 14, 2022 | 01:45 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
No PWR >>> GND?
Recap:
  • The +12 feed test ok at the SAM
  • No blown fuse
  • Also bad: left HL + Marker light !!
> You not getting a blown fuse makes me believe the feed line is not shorted. If it was shorted, an open fuse would be witness...
> The [Left Headlight + Left Marker + Left DCU] do not share power feed... very likely they share GND path to a painted post under driver side carpet. Disconnect batteries and clean GND!
(HL Power grounds nearby but logic GND likely at footwell)
Hope this helps get you fixed
Old Sep 14, 2022 | 03:16 PM
'71 Pinto
Old Sep 14, 2022 | 04:30 PM
'71 Pinto
Left headlamp.
Old Sep 15, 2022 | 12:27 PM
S-Prihadi's Avatar
Just in case you want to check the connector at the headlight itself. This is for ILS 641/642 LED. I done some hours on it.
RHD = Right Hand Drive
See zip, it has all my notes.....its easier to understand than original wiring diagram.
I zipped it to retain its high resolution.
This is another primer on the headlight cross fuse method
https://mbworld.org/forums/e-class-w...leshooter.html
Good luck on your light troubleshooting.
File Type: zip
Old Mar 22, 2023 | 11:43 AM
pmnewcomb's Avatar
Can you share more relating to the pass-through cable? I've found that is the issue, but the cable you show seems to be the one inside the door, not the one that passes through the boot in the door hinge. That is where my problem is for the door. It seems the headlight issue is unrelated.
Old Mar 22, 2023 | 11:53 AM
pmnewcomb's Avatar
This is the cable I need to replace. It has a Yellow, Blue, and White connector on one end and goes under the floorboard carpet. I can't get any info on the part number for it.
Old Mar 22, 2023 | 12:06 PM
'71 Pinto
Provide VIN.
Old Mar 22, 2023 | 12:10 PM
pmnewcomb's Avatar
Thank you, i'll send in a PM.
Old Mar 22, 2023 | 12:40 PM
'71 Pinto
Routes into main body harness as shown in post 7 see attached bulletin concerning replacement. If associated connectors inclusive of pins @ DCU & rear SAM are fine only DIY choice is to trace through body harness but before doing so check CAN voltage distributors.
File Type: pdf
File Type: pdf
