Sponsored by: CARiD
I should look under the hood more often
Old Sep 24, 2022 | 11:11 AM
Boarderjosh10's Avatar
2014 E550
Is my airbox on correctly? It seems like the corners of the box are unable to sit flush. Is this the design or is something off?
Edit**** this is 2010 E550 5.5v8 sedan
Old Sep 25, 2022 | 01:29 AM
Senecat's Avatar
1983 Nissan Shltbox
Dunno. Pull it apart and check it. Doesn't look right to me though.
Old Sep 25, 2022 | 06:51 AM
RA72825's Avatar
Looks like the plastic has deformed and warped. I’ve not seen that before, but it’s probably not worth replacing. Could use a little clean up in there. 😁
Old Sep 25, 2022 | 08:56 AM
pierrejoliat's Avatar
24 GLS580 '23 E450 4matic 12 E350 4Matic
Typical Arizona under hood shot! So darn dusty down there, my car in Tucson looks like that after six months also. plastic warps in the heat, what year and model is that? doesn't look like either of mine and reminds me of my 210 E 320? Either way, if you can set that out in the sun for a while, upside down, it may warp back flat. I would also check my cabin filter, I bet it's a solid wall of sand! you may need to replace that cover to stop the infiltration of dust into the filter and cabin. AutohausAZ is right there, south of Sky Harbor. If youre not interested in buying a new lid, you could I guess use door weatherstripping dense foam to stop the dust infiltration.
Old Sep 25, 2022 | 09:28 AM
pb39374's Avatar
2010 E350 4Matic sedan
M272?
Old Sep 25, 2022 | 12:27 PM
S-Prihadi's Avatar
Due to MB love of plastic.....
M276 Turbo 3.0, if one is not careful pushing down properly into its channel for the seal of the engine's airfilter, sometime on the side of the similar airfilter cover as OP's photo, it will have a bit extra gap than usual.
This is what I am speaking about. https://www.ebay.com/itm/264946156219
See the Torx screws are not equally spaced and in equal quantity per side, some side uses hook/hinge.
Would be better if where I marked green, another torx screw is placed there
Old Sep 25, 2022 | 12:41 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
When this is just a cover and not crucial, even it might allow small amount of bay (hot) air to enter the filter, I would more worry why it warped this way.
MB air filters do have precision-molded lips, who have to go into groves.
I would check to make sure the filter is sitting properly and is not pushing the cover the way it not suppose to.
Old Sep 25, 2022 | 02:28 PM
konigstiger's Avatar
'71 Pinto
Just for ****s and giggles what is part #?
Old Sep 25, 2022 | 02:51 PM
S-Prihadi's Avatar
Looks like M112 / M113
Old Sep 25, 2022 | 07:09 PM
https://youtu.be/yZ97YKSfEZI
I owned that one for 14 years I don't think thats it ?
Old Sep 26, 2022 | 02:59 AM
S-Prihadi's Avatar
His airbox has A112 xxx xxx written on it, usually that means it is for that engine, M112 I think.
Let OP tell us ......
Old Sep 26, 2022 | 02:52 PM
El Cid's Avatar
Veteran: Army
2010 E350 Luxury Sedan, Engine 272 (V6)
Time to begin checking under hood for varmints - chipmunks, squirrels, mice, etc. Several years ago I raised hood and found acorns and pieces of pecan shells on top of engine cover. Got one of those electronic beeping boxes and placed it in the engine compartment and no problems since.
Old Sep 27, 2022 | 10:39 AM
2014 E550
Sorry for my delayed reply. This is a 2010 E550 5.5 V8 engine. It has 2 filters.
I will try to take it apart again and reseat the filters. Based on the comments it sounds like this is not the way it was designed.
Yes it's very dusty and hot here in Arizona. I do high mileage, put 24k miles on the car YTD.
Old Sep 27, 2022 | 01:00 PM
So the largest displacement M113, I had that in my '07 S550
Old Sep 27, 2022 | 01:25 PM
atraudes's Avatar
2011 E350 Wagon, 2010 GL450
Should be the M273. It has the same air filter setup as the M272. I can check mine when I get home and take a picture.
Old Sep 27, 2022 | 01:50 PM
'71 Pinto
May be time to replace housing shop part # 2730900901, check ebay used.
Old Sep 27, 2022 | 02:05 PM
atraudes's Avatar
I see them at Pick n Pulls all the time. It's not a popular part so they hang out and they always seem to be in great shape. I believe the cleaner from the M272 (V6) is exactly the same part.
Old Sep 27, 2022 | 11:37 PM
atraudes's Avatar
Well, mine is the same way. It does look like it shouldn't be that way, but it's fairly reinforced so it seems to be by design
Old Sep 28, 2022 | 12:37 AM
S-Prihadi's Avatar
Well.... plastic can mild deform that way under heat.
It is such a wide area unit, but the screws are so few, that is another issue.
As long as seal can seat well and no dust can pass thru, its allright.
Old Sep 30, 2022 | 11:16 AM
2014 E550
Thanks so much for sharing the pic of yours! It looks the way mine does. This gives me some piece of mind.
Old Oct 1, 2022 | 11:44 PM
pb39374's Avatar
I have the m272. Mine is the same exact way at corners. I thought it was an issue too when I first got the car years ago. But I looked into it and it’s by design. Nothing to worry about.
