ECO is dead...
Edward:
I'm still on my oem Aux batt which was made in 2015. Not sure why the aux batt would matter but who knows with these cars.
Fyi there were no codes on mine when the eco wasn't working. All I can assume is the car estimates batt condition and if not good then it won't risk eco? I don't think it gauges voltage, but probably crank speed or similar to determine odds of actually starting. Well, on my car a voltage check won't tell you, but maybe jump it to boost crank speed and see if it magically starts working again. Or if due, just get a batt before it leaves you stranded :o
Our 350 is a 2014 on its third aux batt, but original main battery (we bought it as a CPO in 2016 so I know it's original). So I think the answer is clear. I recall the other times the Aux batt died that both the ECO and brake Hold didn't work, so that's why I posted here since my Hold still does work. So I think you're right about my main batt losing its capacity (@2chevota, interesting tidbit about your main batt working for a year, thanks for that!). My orig MB unit certainly has aged well, ya gotta give em that! I'll put it on a charge just to see what it does, but the obvious answer is it's time to get a new AGM batt. Big thanks, gents!!
Edward
Not all apply to all cars, but how sensitive the system is, shows my experience with GLE.
Bought the higher mileage car and ECO did not work on it, even I had button on dash. Check with GLE section, but could not get clear answers, so I assumed that my GLE version is not having ECO stops.
Drove well over the year just fine, till 6yo battery start showing low voltage.
Put new battery in it and had ECO engine stop on the 1st red lights I had on my way.
Meaning the battery was good for engine start for last year of its service, however ECO did not classify it as good enough for engine stops.
Right in front, next to the Maverick.
Edward
Edward
It is now, in colder days as in the summer ECO did not work most of the time, what I believe was due to running AC
I also noticed that when I park the car for few days, ECO will take long time to start.
I added a cable with plug in front grille, so I am hooking up battery maintainer when I don't move the car for more than 3 days. This way ECO always work with proper engine temperature.
