2012 E350 - Fuel filler door won't lock shut
Wife refilled the gas in her E350, then when she went to close the fuel filler door, it wouldn't lock shut. Some further investigation seems to indicate that the switch that activates the lock solenoid has failed. Did some searching but can't find the part number or any directions on how to replace it.
Can anyone point me in the right direction?
Karlhardy (05-29-2023)
Received 4,435 Likes
'71 Pinto
Read thread in its entirety: https://mbworld.org/forums/e-class-w...-latching.html
pierrejoliat (03-14-2023)
The problem isn't that it won't close. The problem is it won't stay closed.
Normal operation is this:
EDIT: I'm a dolt. I looked at it again. Apparently while there is only a little nubbin on the gas cap, there remained about 2" of tether on the filler door. And that 2" wound up on the gas cap rest on the filler door, thus popping it open. Apparently the plunger isn't a switch after all. I stand corrected and eat my slice of humble pie.
The following 2 users liked this post by gunbunny:
AllPhonesAretap (03-17-2023),
The following 2 users liked this post by pierrejoliat:
CaliBenzDriver (03-14-2023)
Received 3,448 Likes
MY'14 W212 M276 3.5NA @60kMi
Cap... recap
For other future readers, the fuel door can fail to close for 3 distinct reasons -
In order of likeliness for ya :
Repair cost range from free to around $500. Warranty may sometimes be applied or not.
Content research courtesy of @konigstiger - Follow thread link for complete parts view in particular the $10 spring actuated ejector pin.
- cap cord gets in the way
- ejector does not stay down
- motorized latch is jammed in/out
![](https://mbworld.org/forums/images/ranks/veteran_navy.png)
2014 Cummins, 2014 E250 Bluetec
pierrejoliat (03-15-2023)
#4 is what got me when my wife locked herself inside while i was refueling. Latch pin got in the way of closing.
QUICK RELEASE PULL:
You can access a Red plastic emergency release handle behind the trunk carpeting.
It's useful when the latch is inoperable.
pierrejoliat (03-16-2023)
