2011 e350 service required do not shift gears visit dealer
Anyone have this happen to them? I can’t even get the car in drive to get it to shop. I’ve read it could be the auxiliary battery, brake light switch, or the tcm. Help? Please?
"Do not shift, visit dealer" usually involves the PRND shifter module at the gearbox.
Red Sce light coming and going for a while makes it sound like a borderline voltage issue - Charge batteries and measure running voltage.
Use a scanner to retrieve all faults then you'll get a closer idea about what your car is up to.
This limited issue shouldn't be too expensive to fix.
The issue you report warrants not driving the vehicle until checked and fixed right.
not to stop and visit dealer... it's a built-in curse!
The unsoldered connection pins inside the shifter are causing immediate service needs.
All worked well now. I called the AAA to tow and the gentleman sprayed cleaner and wiped nice the KEY and the key hole and started just like that. Thank you all for your courtesy and support and answers.
Any low mileage deal with basic maintenance records is goood.
Pick your favorite options and your must have
if you can afford it, get a CPO car from a reliable dealer with a good history, and get the 2 year extension on the CPO, so you have 3 year dealer warranty.
