Sponsored by: CARiD
Help needed
Old Jul 15, 2023 | 10:16 PM
Riz187's Avatar
Mercede Benz e220d 2014
Help needed
Hi guys
I have a e220 w212 2014 and recently I ended up with a faulty dpf so got it replacement however 2 days after replacement I noted a new fault which I been informed is likely linked to the initial fault. I got 2 error codes on diagnostic,
1- POOAF72- Boost pressure control "A" has a malfunction. The actuator does not close.
2- P029900- The boost pressure of turbocharger 1 is too low
initially on starting the vehicle at present there is a engine management light present but it works fine upto about 10-15 mins into the journey when the limp mode kicks in and I feel the difference in the drive- limited power.
I would really appreciate any input specially if someone has the similar problem and guide me.
thank you for taking your time out and read this thread
Old Jul 16, 2023 | 07:08 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W212 forum...
Old Jul 18, 2023 | 12:11 AM
Quint22's Avatar
Veteran: Navy
2014 Cummins, 2014 E250 Bluetec
Will let experts chime in but I imagine its because the turbo is acting up or fubared which likely caused the DPF to get clogged up to begin with (not sure of how many miles on it). Replacing DPF fixed that part but the turbo is still acting up.
The experts will know exactly what the codes usually represent.
Old Jul 18, 2023 | 02:52 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
sideways always nice
did you notice how STORED is noted ??
I think this is a transient code.
Take a good long look or show us the associated "snapshot data" to understand when this happens.
