Sponsored by: CARiD
Updated camshaft magnet solenoid leaking?
Old Aug 1, 2023 | 11:23 PM
FireFox31's Avatar
2016 E350 4Matic Wagon
Hello, has anyone experienced an oil leak at the electrical connector on the updated camshaft adjuster magnet / solenoid part # 276-156-07-90?
On my 2016 E350 wagon, all four magnets are 276-156-07-90. Since I bought it used, I don't know if they were replaced, so don't know their age. I checked the connectors on all four and saw no leaking. Also, the M and F connectors on the ECU had no oil leaking.
I checked one camshaft position sensor and it's the old 276-905-11-00, clearly leaking on the electrical connector. For now, I'll replace all four CPS, install magnet pigtails, and monitor the magnets for leaking.
Old Aug 2, 2023 | 06:40 AM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
On my 2016 E350 wagon, all four magnets are 276-156-07-90. Since I bought it used, I don't know if they were ever replaced. I checked one camshaft position sensor and it's the old 276-905-11-00, clearly leaking on the electrical connector. For now, I'll install magnet pigtails and monitor them for leaking.
I assume you cleaned all connectors with electronic cleaner, in particular, the connectors towards the main harness.
It seems newer parts have taken care of this issue, but the truth can only be known by waiting for feedback and "time". Say new parts lasted 50K+ miles, and the new ones last 80K+ miles, it may be the vehicle changes owner, and the counting starts again.
Advice: make it a regular item to check every oil change. If leaking -> replace; otherwise, enjoy your vehicle until next oil change
Old Aug 2, 2023 | 10:27 AM
chassis's Avatar
2017 GLE350 4MATIC
And when you buy sensors and magnet, buy them from the dealer. Ignore "part numbers" printed on these parts from "other sellers". Electrical parts in particular are subject to inferior quality in the aftermarket.
Old Aug 2, 2023 | 11:23 AM
JCM_MB's Avatar
in particular, "unknisium manufacturers"
Old Aug 2, 2023 | 01:48 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
The supply chain distribution is extra overloaded with hips of "look-alike" junk parts.
Do you think we can trust FCP Euro, PELICAN Parts to sell dealer grade -or instead do these distributors have "eBay copy-cats" ... what store can we trust for key engine components (CPS, Plugs, TENSIONERS,.... ) ???
Old Aug 18, 2023 | 01:27 AM
FireFox31's Avatar
I clarified my first post. I checked all four magnet connectors and there was no oil in them. The one CPS connector I checked had oil. I bought four new CPS from FCP and will install them. I'm also installing magnet pigtails even though the magnets are the new part number.
Did any of these cars come with the updated magnets?
I trust the quality stores Autohaus, eEuroparts, FCP, Pelican, Parts Geek, RM European, and ECS Tuning. I've spent many thousands of dollars at FCP for my Volvos and am confident in the quality parts I receive. You can also buy from the dealership at https://mbparts.mbusa.com/
Old Sep 3, 2023 | 11:17 PM
KillBillz's Avatar
2014 E550 4Matic
For piece of mind, you should also install the sacrificial wire harness. With these installed, the oil would never make it into the engine harness from leaking solenoid magnets. I got them from FCP for $10 each. 5 mins install.
2711500156
Old Sep 4, 2023 | 09:25 AM
chassis's Avatar
2017 GLE350 4MATIC
Buy from your nearest dealer or mbparts.mbusa.com
OIl and oil filters are OK from retail parts shops or ebay, amazon, etc. Everything else = dealer. Especially electrical parts.
Old Sep 5, 2023 | 10:17 PM
S. Madman's Avatar
2012 E550 sedan 2019 E63 Wagon
Did you also checked the cam sensors connectors?
Old Sep 6, 2023 | 09:31 PM
FireFox31's Avatar
Thanks, I bought four camshaft magnet/solenoid sacrificial pigtails from FCP Euro for $39. That's cheap insurance in case the updated magnets leak.
At least one of my camshaft position sensors is leaking into the harness. I bought four from FCP for $186. I'll install them once I can find some time to remove the intake manifold. Thanks again for your input.
Old Sep 6, 2023 | 09:57 PM
JCM_MB's Avatar
Have you also got the sacrificial harnesses for the camshaft position sensors? FCP Euro does not carry them (call them and confirm just in case). I have only seen them on eBay mislabeled for the M278 engine. Both engines M278 and M276 use the same sensors.
FYI, here is one of the links: https://www.ebay.ca/itm/2011-20-Merc...0-89d79472c580
Old Sep 14, 2023 | 06:34 PM
FireFox31's Avatar
Thanks for the link. I did not get the eBay CPS pigtails because I am suspicious of them. I expect that the solenoid/magnet pigtails have a method of preventing the oil from wicking, though I haven't disassembled one to be sure. I don't know how to confirm if the eBay CPS pigtails have that prevention method. If they're simply longer wires with no prevention, it seems like their purpose is to buy you some time for the oil to travel down them before reaching the engine harness. How long would it take for the oil to cross them? We'd have to check them more frequently than that in order to catch a leak.
I've already got oil coming out of at least one CPS to the harness, so it might travel from the harness through the new pigtail and to the new CPS, making it look like a leak. Also, I don't trust the quality of a part that's not from Mercedes or one of their OE parts suppliers. I'd hate to have something like a bad solder/crimp cause high resistance and throw off my CPS readings, causing other problems. For all of these reasons, I'm skipping the CPS pigtails and plan to check them for leaks at every oil change... if I can clean the harness which they already leaked on to,
Old Sep 14, 2023 | 09:13 PM
KillBillz's Avatar
2014 E550 4Matic
The sacrificial pigtails does not give the oil a chance to travel pass them and damage the CPU. It eliminates the issue. The parts I purchased from FCP Euro were OEM Mercedes parts.
Old Sep 14, 2023 | 11:14 PM
FireFox31's Avatar
Is anyone willing to cut open a magnet/solenoid pigtail to determine how it prevents wicking? Then cut open an eBay CPS pigtail to see if it has the same protection and build quality? Without that protection, they seem pointless.
Old Sep 14, 2023 | 11:39 PM
KillBillz's Avatar
2014 E550 4Matic
At $10 each maybe that can be a project you can undertake. I feel pretty safe with my $40 investment.
Also at $10 each why would any bother with a eBay knockoff ?
Old Sep 15, 2023 | 11:05 AM
JCM_MB's Avatar
Is anyone willing to cut open a magnet/solenoid pigtail to determine how it prevents wicking? Then cut open an eBay CPS pigtail to see if it has the same protection and build quality. Without that protection, they seem pointless.
Do you trust MB/OEM pigtails but not someone else's work? MB sold you a car with a significant defect that can go into the thousands and for some, the current market value of their vehicle. At that point, to be safe, the only way to be 1000% certain those pigtails work as a deterrent, it is to order the connector yourself and make them at home.
If the oil still wicks through, nobody is to blame.
Old Sep 17, 2023 | 08:04 PM
ghlkal's Avatar
2012 E550 v8-Biturbo
That is, unfortunately, a good point
Old Sep 18, 2023 | 10:56 AM
managed chaos...
Every system is engineered with an Easter-egg that commands expert service -
the pigtails have nothing particular to stop oil-capilarity besides they can be replaced at lower cost than ECM harness.
I reckon plastics on the engine heads get toasted by the limited oil circulation!
Old Sep 19, 2023 | 12:12 AM
S-Prihadi's Avatar
Intermediate connector ( pigtail ) uses male and female tinned copper terminals, that breaks a non stop wire core/strands , where the wire core/strands are the "wick" ( imagine candle wick ) which is
the oil transport mechanism. Actually if the pigtail MALE and FEMALE connector seals are good, even with intermediate connector eventually oil filled up that intermediate connector and oil transport will continue.
However, when the extra pigtail is there and it still has NEW oil traces at its end point, we then replace the leaking magnets solenoid or CAMshaft sensors and that pigtails...hence the same is sacrificial pigtail.
