Will any AC Compressor Fit My 2014 E350?
Hello my friends from MBWorld,
I suspect that my AC compressor on my 2014 E350 has gone bad, or at least the AC Compressor clutch. As you guys probably know, it's not a cheap part and I was thinking about getting it from my local junkyard. There is a 2004 E320 and a couple of 2008 E350s that I was thinking about pulling the AC compressor from.
Do you guys think that it will be ok to install those AC compressors into my 2014 E350 or will it not be compatible?
W212 MY'14 M276-3.5NA @75kMi
May be you're lucky and you just replace the clutch coil after testing other things around like ohms, GND.
If you don't have to open the high-pressure dry circuit... well then don't
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
