Steering Wheel does not go up or down
2015 e300
thanks in advance
Check fuses at F-SAM who is charge of this convenience feature.
The telescopic steering column convenience entry use 2 electric motors that have an abnormally hard life.
The factory mechanical adjustment are poorly made and need to be redone.
get it to your driving position followed by
be sure to disable "convenience entry" through Settings menu.
Problem solved else fix column for a great opportunity to meet two solderless VIP nodes: the SCM and King-pin of awesome CAN troubles:
The amazing EIS Module.
The steering wheel electronic is built to notice abuse to the point one may guess the clunky column exists to be trigger.
... anyways when in doubt scan to collect rare clues.
optical position encoder and unsoldered pins
naked optical sensor and pins
steering wheel controller... 😅
steering wheel side buttons
Take it easy with luck
When I fixed that my car noticeably started to drive planted straight on the freeway instead of the electric rack hunting left and right unstable.
A few of the MB systems suffer from issues that lock out best performance like driving straight, not burning oil, not killing batteries.... European luxury.
By the time cars are all electrical... people will need to fix new things that are being tested right now! The old "Balance shaft" game will be replaced by HVAC weaknesses.
how many issues can this pack ?
The big question is how loose is too loose... that is why I opted in for the Grand-Tour - I don't regret the journey one bit to encounter amazing EIS... A lot of things got exponentially better.
In december I realized my steering wheel was no longer moving up 'n down automatically with my front door...
TILT adjustment nut...
I got under the dash and loosened the nut and adjusted the freeplay. Done!
Then one month later, again!
Now what?
Same thing, the nut quicky got tighter by operating the convenience. The repeat calls for a different fix.
This time I lubricated the nut with dry-lube spray so it has more friction on its shaft than the black plastic piece it is operating.
It this happen one more time I will clean the assembly with brake cleaner then Epoxy glue it to the nut.
crawling under dash: column
The one thing I still can never do is.... bang on my steering wheel. 😳
When the nut gets itself tight, the motor simply can not move it.
however, just yesterday I picked up my 2014 wagon from th dealer and the steering wheel was stuck in the upmost position. so I complained that they broke my steering wheel (lol) and I just took it this morning and they fixed it while I waited. They said it was a simple software fix. Here’s the invoice attached.
go figure 🤷🏽
go figure 🤷🏽
This free of charge relearn procedure is not fixing the hardware binding. This module does not get disrupted into forgetting its learned positions.
At any rate hopefully the repair will last a while.
The real fix is to have a counter-nut to hold position or epoxy glue it with JB-WELD. Cheaper than $3G column, right?
LISTEN TO TILT: now my tilt sounds like butter, super smooth, fast easy no laboring... lubing one nut only maybe good enough after all
seat module says no mo' convenience
These excellent questions i dont have the answer for as I can not believe doing adaptation have a chance to fix a tight tilt mechanism.
Nor do i think this controller can forget its location to need relearn. The seat controller itself is reliable besides harness.
I think the dealer tech.gave you a free steering wheel bang procedure. All 5 secs of it.
My chassis mostly has good clean GND.
One way possible to loose position is with marginal GND. If this happens again soon, keep GND's in mind.
