SBC(Sensotronic Brake Control) problem after changing brake pads and discs
PS : i don't have any errors that comes after brake change and hand brakes absolutely not touching the discs
SBC on SL model : https://youtu.be/4B3wX5-cYng?si=XMTjVD2ooc0L7vBf
I'm kinda surprised to see a solid disc rotor. What year is your car and what country are you in?
Also, SBC requires the use of a scan tool to operate the brake bleeding procedure, which is somewhat involved and does NOT follow the traditional process of starting with the furthest wheel from the master cylinder and working toward the closest wheel (i.e., right rear, left rear, right front, left front is NOT the order to follow).
I have a w212 facelift E220 CDI from 2013, bought from Germany
I don't have any scan tool, maybe should bring the auto to a car service and hope they can fix that but till then I can get maybe some help 😉 as long as I didn't got any errors I have to recalibrate the pistons and should be fine
- iCarsoft MB V3.0 (not MB II)
- Launch Creader Elite BENZ
- Foxwell NT510 Elite
I recommend you get your own Mercedes-specific scanner, such as iCarsoft MB V3.0, LAUNCH Creader Elite BENZ, or Foxwell NT510 Elite so that you can scan your car at any time. In the US, they are pretty inexpensive compared to what I've seen them sell for elsewhere. Still, you really need one. They are small enough to store in your car (such as the fuse compartment in the trunk). Sometimes a code may cause the car to run rough and clearing it will restore normal operation until you get a chance to check it out.
(Do not waste your money on the iCarsoft MB II. It is slower and requires you to check each module separately for codes. MB V3.0 runs an automatic scan and will identify modules with DTCs so you don't need to check 30 or 40 modules individually.)
Are we sure we aren't talking about the ABS system?
I ordered my W212 with the option that pilots my brake pressure as the car is closing in with the car ahead. I love it everyday, like the electric steering rack.
The driving skill of adjusting the foot pressure on the brake pedal to stop with moving traffic, will soon be forgotten.
Having an interactive pedal is good driving comfort. Much like automatic tranny, no cluch, no stick shift and up to 9 gears... pure bliss
When all that technology works it's fantastic then we get the engineered nightmares to pay for it.
Step 01: buy priceless design core
Step 02: double check amazing wiring
Step 03: come again real soon
> Reduced performance mode:
Imagine what happens when the car quit managing braking distance or skidding over slick roads.
Every working system is built to disfunction in a safe way to prevent it becoming extra dangerous from disrepairs.
Recently some of us discovered brake improvement due to lowered crankacase pressure. Most ppl brakes work poorly but they are not aware of it.
Now that technology is adding a layer of control over the spinning wheels, we need to learn signs of poor performance... "dry sliding pins", solderless ESP).
No SBC, different problems anyways.
> Troubleshooting fault modes
Not all degraded performance come with a matching code. It's up to us to pickup on clues of poor performance.
It is a perfect struggle to get the high maintenance princess taken care of.
Recognizing an underlying issue is present with these networked systems is half the battle.
> Repairs:
Luckily German manufacturing is really well tested, random failures are parts per many thousands.
Repairs are simple once problems are identified correctly. That's the hard part. Root cause is always a gem to discover.
> TIP:
- If you have a stable electrical system you are ahead of the game for way less troubles if any.
- Get your voltage and currents under control to minimize riples.
- This will help keep the poor solderless connections as quiet as possible until you have fix or replace modules.
Show us this exotic options on a W212, it will be a great rarity.
