Sponsored by: CARiD
Specific rear alignment specs for 2014 E550 4Matic
Old Feb 11, 2024 | 08:36 AM
BillWoeb's Avatar
2014 E550 4Matic
I have joined the ranks of those with right rear tires worn on the inside edge.
I rear the posts about adjustable bushings and about model specific suspension specifications.
Would someone point me to the rear alignment specs for my 2014 E550 4Matic sedan?
Many thanks!
Bill
Old Feb 11, 2024 | 01:18 PM
Sunnyslope48's Avatar
2016 E350 Sport 2WD
Right tire as on passenger side or driver side? It depends on perspective, correct? My indie shop says that it is very common for drivers side inside to wear noticeably and the only practical way to address is to keep the tires rotated.
Old Feb 11, 2024 | 04:32 PM
BillWoeb's Avatar
2014 E550 4Matic
My bad - passenger rear is the one worn. I want to keep the rear tires on the rear so I guess I will rotate them side to side on the back.
Old Feb 12, 2024 | 06:25 AM
ygmn's Avatar
2015 E400 Sedan
dont fight it and keep paying for tires early:
Mercedes 502126 K RearAll W204 C207W212, W215, C218, R231 incl. AMG /Black Series ( Set of 4 ) Camber & Toe Adj. Bushes - K-MAC Camber Caster Strut & Bushings Worlds Largest Range (k-mac-camber-kits.com)
I purchased for my car and will get them installed soon when it warms up - I can wait as I only drive about 2-3k per year with this car now.
Old Feb 12, 2024 | 12:26 PM
BillWoeb's Avatar
2014 E550 4Matic
Oi! My rear camber is -2 deg both sides.
Kit on order and will be installed tomorrow.
Old Feb 12, 2024 | 01:21 PM
MercFiveHundred's Avatar
2014 E550; 2003 E500
Just FYI, if you have an air suspension E550, you will need to ask the dealer to make sure they align with the ride height correctly set up. I don't know the specifics, but I had the same problem with the stock Conti's and changed to the Michelin's + dealer alignment in CT. I do not have any abnormal wear in the rear as of now - about down to 6/32. If you don't have air suspension, I wonder if there is a difference in alignment specs between the 'Luxury' vs 'Sport' suspension.
Old Feb 13, 2024 | 09:39 PM
Quint22's Avatar
Veteran: Navy
2014 Cummins, 2014 E250 Bluetec
The website is really bad, can only narrow it down to w212 which has like 200 items to scroll thru.
Curious how recommend the product when havent used it yet? I know there were some questions about it from others just curious
Old Feb 14, 2024 | 08:08 AM
BillWoeb's Avatar
2014 E550 4Matic
I had Belle Tire in Canton MI source and install the camber-adjustable bushings. Original rear measurement was -2.1 deg camber on each side. Now -0.5 L and 0.7 R. Tires were also remounted on opposite wheels in the rear to even out the edge wear pattern.
Time will tell how this works!
Bill
Old Feb 14, 2024 | 08:59 AM
ygmn's Avatar
2015 E400 Sedan
I did not recommend; I just pointed out a solution.
I suggest in this case with this issue everyone does the research themselves as issue could be something else like bad subframe and other rear suspension bushings.
I did and looked for months at all sorts of "fixes"
There are other solutions but I chose this K-Mac.
For me and my car, I discussed the issue at length with my alignment/tire shop; while they replaced LH rear tire leaking air from the worn out, belt showing tire last year.
I showed them possible solutions I found on the net.
We decided the K-Mack route
I hope this explains my post better as would never want anyone to buy anything on what I post but I hope the would do their own research.
Old Feb 14, 2024 | 09:01 AM
ygmn's Avatar
2015 E400 Sedan
Bill
how did you get the kit so fast?
mine took weeks but I did go cheap shipping.
Old Feb 14, 2024 | 11:28 AM
BillWoeb's Avatar
2014 E550 4Matic
Apparently there is a readily available bushing kit out there which is on the supplier list for Belle Tire (a Detroit area tire and service franchise).
I admit I do not know the brand of the adjustable bushing. But when the service writer said it was available overnight, I said “go ahead”.
Bushing replacement and cross rotating the rear tires (dismount and remount on opposing rims) plus alignment was $800
Deal.
Old Feb 15, 2024 | 03:55 AM
K-Mac's Avatar
SPONSOR
Mercedes-Benz CLK 550
W212 - 200 items !!
W212 there is actually “12” kits / Part #’s that cover every model (yes entire K-MAC Mercedes Benz adjuster kit range 1969 to 2024 there is over 100 P/N’s) !
Front Camber and Caster, Rear Camber (and extra Toe to compensate) along with uprated bushings.
Like the new car industry it is all about constant development. We do not merely source imports and simply relabel but proudly have “IN-HOUSE manufacture” - allowing “TOTAL CONTROL” OVER QUALITY AND IMPORTANTLY RAPID CONSTANT DEVELOPMENT.
ALWAYS THEREFORE ENSURING Biggest adjustment range, Ease of fitting along with simplicity of adjustment (K-MAC unique patented design allows ultimate adjustment - on car single wrench “direct on alignment rack” UNDER LOAD).
LATEST Design Breakthrough - ALL K-MAC Mercedes Benz Front and Rear bush adjuster kits no longer require “SPECIAL TOOLS” OR TIME CONSUMING “CONTROL ARM REMOVAL” to remove and replace bushes !
Providing more then enough adjustment to resolve costly, premature edge wear issues.
SEE SPOILER RE W212 COMPLETE F/R RANGE.
Kevin
Spoiler
AUDI to VOLVO - K-MAC Experience Of Resolving OEM Suspension Shortcomings Since 1964 !
