Intake manifold pressure sensor problem? (1916?)
This is what I got after the Check Engine lights on...
I got the above code after the Check-Engine-lights on. What should I change to remove this error code?
I would love to know any links or videos for this job.
(if it is not a big deal, I would like to do it by myself)
Any information would be a great help for me
Important but not a pricey issue.
-- The question is why ???
I don't think you need a sensor they are reliable solid state.
-- Has anyone been under your engine bay recently?? Look around intake plenum for oddities.
-- Read your live MAP sensor ....
what value: zero or ?
I am really not familier to engine bay...
I tried to look under the hood and noticed some swoosh sounds around the MAP sensor.
Vacuum hose(?) which connected to the MAP sensor was leaking... I would like to replace the hose, but I don't know which size/length of the hose will be needed.
Also I don't know this hose connected from which position to the MAP sensor..
Do you have any idea about this? Do you know the OEM part numbers for this? or could you recommend me a other product for this matter?
Many thanks,
Many thanks,
I was suggesting to "test before replace"...
