Sponsored by: CARiD
pre-emptive battery swap
Old May 12, 2024 | 02:43 PM
Alandf's Avatar
2016 E350 Sedan
Is the battery in my2016 E-350 AGM or "regular" lead acid.
Original battery was A 000 982 21 08 12V 80AH 800A it was replaced under warranty with A 001 982 81 08 12V 80AH 800A with an end date code of 5/19.
I want to pre-emptively swap out this battery so that I don't get stranded. There is no point in going to the dealer and paying high price for a battery and installation. It is an easy DIY.
But, I don't know what battery to purchase. Should I purchase a Mercedes battery at the dealership for over $400? I can go to O'Reilly, Pep boys or Costco and spend $150.
I need to know the size and group number and whether it is AGM or Regular Flooded Lead Acid.
All answers appreciated.
Additionlal question..I know that I should swap out the small battery in the trunk at the same time. But, I do not know any of the specifications or where to purchase. Amazon has similar but not the same.
Old May 12, 2024 | 09:38 PM
Bruce Hubbard's Avatar
W212
AGM. Premium grade battery that usually lasts around 10 years.
You need to replace it with another AGM not a lead acid
You need a stop-start battery for the Mercedes ECO stop-start system
Mercedes use Varta batteries (German for a German car)
Expensive from MB Dealer
I use Century AGM (Australia) DIN75LH AGM stop-start battery
For the battery in the boot
you may be limited to one from the Mercedes Dealer
The battery has to have a vent hole on the side of the battery at the top
and there is a vent tube that connects to it and vents any gases to the outside of the vehicle
If gasses are just allowed to escape into the boot it will rust out the boot
Old May 13, 2024 | 12:58 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
only OEM grade or better
+1 👍
besides hydrogen is an explosive gas when conditions are met.
Old May 13, 2024 | 05:28 AM
JettaRed's Avatar
Veteran: Army
Look it up .
www.fcpeuro.com
www.autohausaz.com
www.pelicanparts.com
www.ecstuning.com
www.rmeuropean.com
www.eeuroparts.com
Old May 14, 2024 | 12:25 AM
Edward993's Avatar
2014 E350
Hey Alan,
The AGM from Walmart is made by Johnson which is one of the biggest makers of auto batteries. I've used the Walmart EverStart brand in many cars within the family and firends over decades ...never a hitch, not a one, all lasted well beyond their expectations! Replaced my wife's factory MB AGM with a Walmart AGM less than a year ago and it's been stellar, as has every one I've bought from them, I think I used an H8 (double check, though) which is the biggest battery that fits in its spot. Side note: Costco sells Interstate AGMs at the same price as the Walmart Everstart, but I didn't see it in time.
The Aux batt in the trunk: leave it alone till it dies. It does nothing for you that is critical ...I've had it fail twice since 2016 fwiw. All that happens is you lose the ECO start function (yay!), but also the brake hold function which I actually like. So it's not going to leave you in a lurch if it goes on you. Look up various internet sites and get that one mailed to you ...at like 1/4th the cost MB wants!
Edward
Old May 14, 2024 | 01:48 AM
cetialpha5's Avatar
Originally Posted by Edward993
Hey Alan,
Edward
Johnson Controls used to make the batteries, but they sold off their entire battery division to Clarios. Many of the same AGM batteries out there carried by Interstate, Autozone, Advance Auto, etc are made by Clairios. Walmart is a tossup, they source batteries from both Exide and Clarios, depends who is closer to them. Even Varta which is the OEM battery is made by Clarios. They have factories all over the world. But either Walmart or Costco which carries Interstate would be cheaper. For Walmart, you might be able to tell if it's Exide or Clarios depending on the code on the battery, may start with EX or something like that if it's Exide. Exide is considered the worst of the 3 main battery makers. Everyone else basically rebrands.
Old May 14, 2024 | 09:46 AM
streborx's Avatar
Top Answer: 1
G550
Many private label brands such as Diehard and Duralast offer 3 grade levels of batteries, differentiated by price and warranty term. I wonder if all 3 grades are the same battery, packaged differently, and what you're paying for is the warranty period. Batteries are a secretive industry. I'm surprised government regulations don't mandate manufacturer labeling, date of manufacture and country of origin, all in standard format.
Old May 14, 2024 | 03:23 PM
cetialpha5's Avatar
Some of it is the warranty and some of it is the type. They make regular lead acid batteries and then AGM batteries. Walmart used to have a cheaper 1 year battery on the shelf. I don't see it anymore though.
Old May 15, 2024 | 12:37 AM
Edward993's Avatar
2014 E350
Fwiw, the Walmart EverStart I referenced (in post #5) says "Johnson Controls" on the label. It's my first AGM EverStart, but the many others in the past have been rock-solid lead-acid batts that all outlived their warranty period by good margins. Again, fwiw
Edward
