Sponsored by: CARiD
What are these 2 errors in Launch scanner and how to fix them?
Old May 20, 2024 | 03:12 AM
Spruze's Avatar
Mercedes E250 W212 Diesel- OM651
car is having no problems but on scanner showing these two
thankyou
Old May 20, 2024 | 06:01 AM
JettaRed's Avatar
Veteran: Army
They are stored. Clear them and see if they return. They can probably be ignored. Did you select the magnifying glass to the right of STORED to see a further explanation?
Old May 20, 2024 | 09:52 AM
Spruze's Avatar
Already tried clearing them but they are back after some time! What does it exactly mean?
and yes the magnifying glass is just useless google search with the code. I think the ignition lock error is because the precious owner of the car got its steering lock removed.
Old May 20, 2024 | 05:58 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
grumblings transients faults...
these ghost faults are transients. They are marginally active conditions market as stored. This is a way to request service attention.
For our practical purpose, transient faults are actively not working well.
1 > Aircon flaps...
-- The fact both L+R bith trigger at the same time means the issue is something they share in common.
-- The solderless flap actuators are not expected to go the distance without greasing service but then each would trigger faults separately!
-- The short list is then either the painted footwell GND post or the solderless AAC module itself. Of course connector oxidation with A/C condensation is also eligible to mess up harmess connectors.
2 > Parktronic stored transients
-- Poor connections can have gotten soaked through loose connectors ..?
-- "Deoxit" protecting oil may help renew oxidized contacts.
-- Extremely long skinny wiring traveling near noisy harness can pick-up disruptive glitches.
-- Explore this circuit specific grounding location.
Hope this helps guide your troubleshooting.
