Sponsored by: CARiD
Will an incorrect leakdown test lead to A+ results?
Old Jun 11, 2024 | 10:55 PM
mgiara's Avatar
2013 Altima, 2011 E550
About to start the third of my 8 cylinders and the first and second I did both scored 99%+
Did not warm the engine first.
Am I on the wrong stroke to be getting such (too good to be true) results?
Old Jun 11, 2024 | 11:31 PM
mgiara's Avatar
third of 8
Old Jun 12, 2024 | 12:17 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
test procedures
I am not a leak down tester...
double check you shut off inlet air before concluding nothing is escaping through old valves and ring set.
...more help's on the way ✌️
Have had a look inside your cylinders wall now plugs are out ??
Old Jun 12, 2024 | 01:10 AM
mgiara's Avatar
No worries, thank you for your response.
I don’t know what inlet air means?
I have not looked inside the cylinders yet, but I will buy a boroscope after finishing this test and post the results.
Old Jun 12, 2024 | 01:27 AM
inlet air comes from shop air tank
"inlet air" comes from the air compressor.
yellow inlet supply line... outlet is black line to cylinder
I am not much of a "leak-tester" but noticed you have both gauges maxed out...
I think you'll want to dial the tool pressure regulator towards half.
In case this is your personal vehicle, don't risk blowing off the rear cam-cover plugs ✌️
