2011 Mercedes E350 Belt Makes Squeaking Noise on Start UP After Sitting a While???
I would think belt would be faster than that, if the sound is from a pulley.
BTW, aside from serpentine tensioner, did 2 of the guide pulleys get replaced too ?
This is the 3hz I speak of :
Your video is a 29FPS. So 1 second it has 29 frames. Above is I cut exact 1 second, 50th second frame 1 to frame 29.
The one in cyan blue is the audio, only 3 chirps.
Maybe your PCV is the one making the noise, like below video : Below is M276, yours is M272, but it would be similar PCV system
M156. The chirps is as slow as yours.
Yes, that is the plan as I mentioned in the opening post. They are backed up and it will be a few days before I can get it to them. While waiting just wanted to see if anyone else had experienced this problem.
https://youtu.be/Hz7MITheAw8
https://youtu.be/kQN21-KV63Q
Pretty typical on these engines.
E350 Still squeaking on startup after replacing pulleys
There is nothing more basic than this for a specialist doing a belt job... it's hard not to fix it when you're paying top dollar for the best MB experts.
Tensioner + belt+ idlers replaced then this!
These crickets sounds like a pulley misalignment or one of the loose accessories is wobbling.
Belt needs to come off, free play inspected. An MB expert will know which pulley is built to walk off its shaft (steering pp?).
Normally that 5mn is included in the repair without taking a 2nd mortgage.
Sorry a basic job got messed up into this. Trust that this happens to the best of us.
You know there's more maintenance coming your way, find true specialists to serve your needs.
Tranny + differential oils are ASAP!
The car has always been serviced at the dealer where we purchased it from here in Houston. This is a strange problem though in that it is only audible after vehicle has been sitting overnight and last for a minute or two. The dealer charged $1,400 to replace just the belt and tensioner and the issue came back. They wanted another $1,000 to replace the two idler pulleys. I found a more reasonable repair shop that changed them for $200. Issue is still there and has me concerned because my wife drives this car. Mainly concerned something could freeze up and break the belt while highway driving. I will get it back to the shop next week so they can investigate further.
The dry idlers are the first parts to go bad then the belt and the bad tensioner.
Having a Mercedes dealer charge $2400 to replace $100 entry level parts in reverse order... is why you did the right thing to find a knowledgeable shop.
Give them your maintenance jobs to keep your car on the road without costly failures.
Ask your shop for tranny + diff oil service.
Next review records for ignition sparkplugs and coils while you're at it (TX has high heat that age coils prematurely).
Timely maintenance will save you bundles in unnecessary repairs.
The super long serpentine transfers power to all the accessories.
Pointers... :
- one of your accessory is seizing up
- belt/tensioner mismatched (FCPe did that to me!)
- misaligned pulley
Your excellent indy shop will have you fixed in no time. Until then keep an eye on the water temp gauge, pump is a belt accessory.
Pointers... :
- misaligned pulley
Shame on the Mercedes-Benz dealership here in Houston for doing that considering they charged me $1,500 to change the belt and belt tensioner. Just the labor included in the $1,500 total was $900. On top of that they wanted another $1,000 to change two additional pulleys when we first brought the car back to them to check their original work instead of checking the belt which would have resolved the issue. So much for having your car serviced at the dealership!!!
Glad everything worked out exactly as planned.
I got my first Mercedes, a 2004 SL500 with 50k miles back in 2017 from a coworker. She had taken her car in for a B Service and $3500 later they gave her a list of recommended repairs and services totaling $10,000. She was sick of paying for a car that looked like it was dying. They offered her $10k as a trade-in on a shiny new GLE. Knowing I was a car guy, she told me the story. I offered her $10k on the spot, promising to take excellent care of her "baby". Later, I was able to do all the recommended stuff for a little over $1000 in parts (water pump, spark plugs, lower control arms, trunk struts, etc.). Some of the stuff was not even needed to be replaced, like the water pump.
What hourly rate do they charge to come up with $900 labor? What belt and tensioner costs $600? Your receipt should show an itemized list of part numbers and procedure codes. Check FCP Euro for parts prices and someone should be able to look up the hours allotment for the labor in ASRA.
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
