Sponsored by: CARiD
2010 E350 Speaker issues
Old Oct 3, 2024 | 09:06 AM
Trahkle's Avatar
Hello, I just purchased my first Mercedes, used, 4 days ago. I've noticed that only the 4 door speakers are working. I checked the front/ rear balance, that only moves sound from the doors. I've turned PRO Logic 7 off and on, and I don't notice much. I did look in the trunk, and I can see one speaker on the right, but I can't get to it. My build code is p01 and 810. I'm also not hearing a front center speaker, I'm only hearing the 4 door speakers. Any ideas how to get the other speakers turned on?
Old Oct 3, 2024 | 09:10 AM
Trahkle's Avatar
WDDHF8HB4AA114235. Just a little more information, if that helps
Old Oct 3, 2024 | 07:24 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W212 forum...
Old Oct 3, 2024 | 08:39 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
CONGRATS & WELCOME....
Congratulations on your excellent choice. The sound system in this chassis is computerized.
You will best use a LAUNCH CREADER SCANNER to read the fault from this system.
It seems there's an issue with missing F/Rcenter channels. The scan will halt a wild hunt for clues around digital sounds fiber.
Old Oct 3, 2024 | 08:53 PM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
Or, the amp blew up and smoked the HK speakers....like mine in TWO cars
Old Oct 3, 2024 | 09:12 PM
they don't have "non-smoking policies" in these cars...
his door speakers are ok at this point.
read deck is missing
Old Oct 6, 2024 | 01:59 AM
Bruce Hubbard's Avatar
W212
It's a subwoofer amp and speaker in your photos
Usually the subwoofer is cooked
You can disconnect the speakers from the amp and run a DC continuity check on the voice coils
The voice coil windings are probably cooked and the speaker cone is frozen in the magnet
Amplifier is probably ok
Check the speaker in the dash the same way, for DC continuity of the voice coil
Someone has probably been hammering the crap out of the sound system with the doof doof
https://mbworld.org/forums/e-class-w...w212-e250.html
