Sponsored by: CARiD
Chasing Mercedes E350 Misfire
Old Oct 24, 2024 | 11:07 AM
JettaRed's Avatar
Veteran: Army
Interesting the Bosch rear sensors are also made in Japan, like the NTK ones.
Old Oct 24, 2024 | 01:14 PM
Tdavid1's Avatar
I went to grab my actual scan tool from work and found both my cam readings to be off. Is this my issue? Could the car have just jumped out of time? Or is the misfire causing it?
Old Oct 24, 2024 | 01:20 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
misfire don't cause timing issues on these engines
but the other way around...
timing issues do cause misfires, guaranteed they can.
here both intakes are shifted
for only one misfire...
Is that with engine running now???
Old Oct 24, 2024 | 01:21 PM
Back to.... O2 oil soaked ??
Gents: what cause funky lambda + misfire??
"$10K-Oil-in-Harness!"
Go check CPS + ECU for oil swamp
What caused the misfire after Gym...
is oil soaking into lambda!!
Time for spray cleaning + CPS + pigtails + Lambda
There you have it.
Old Oct 24, 2024 | 01:23 PM
Tdavid1's Avatar
Back to O2....
Dam so I’ve got a timing issue..? What exactly would I need to replace…? Or is this sucker going back to the auction
Oh you’re saying I need a new CPS and lambda? I’ll check for any oil.
Old Oct 24, 2024 | 01:28 PM
you're good unless bad block or tranny.
So far this bargain is a keeper.
parts are can be super cheap.
Old Oct 24, 2024 | 01:33 PM
  #32
is this with engine idling or engine off ??
Check Cam sensors for oilyness.
Old Oct 24, 2024 | 01:36 PM
  #33
Jaybird123's Avatar
2015 E63S Sedan, 2014 E550 coupe
Honestly my first guess was VVT (cam adjuster) gear(s). If that job is similar to the m278 one…it’s a doozie. I did Bank 2 intake cam adjuster last year, have lots of pictures if you dive into it. That specific part is not cheap unless you go aftermarket.
I hope for your sake (and your wallet) it is a simpler fix.
Folks, does this model also have the timing chain stretch issue in certain years?
Old Oct 24, 2024 | 01:46 PM
  #34
I think secondary chains ok at 100kMi, they are short and separate and use a weak tensioner with single HPFP for 276-NA. Sort of easy life besides poor lube factor.
The VVT No1 job is to compensate exact cam position for chain wear... when given enough oil pressure.
  #35
Tdavid1's Avatar
Engine idling. New codes…
looks like I need a need a timing/cam adj job. Thoughts?
Old Oct 24, 2024 | 01:50 PM
  #36
any rattling at all then ??
Extreme No say intake VVT Gears are not locked.
check cam sensors at least the one easily accessible from Bank1 intake:
oil galore in sensor?
Without ratlling and extreme position + extreme Lambda is textbook... "oil in harness".
Old Oct 24, 2024 | 01:53 PM
  #37
Tdavid1's Avatar
seems they are not locked!
rattles only in the morning when I first start it. One of the first things I did was replace that cam sensor (bank 2) but didn’t change anything. The car doesn’t run that bad tho, If it is out of time wouldn’t it run much worse?
Old Oct 24, 2024 | 02:01 PM
  #38
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
It seems you have to remove the camshaft position sensor (4 of them), put the engine in timing and check the holes for the tone/reluctor ring to be in the exact correct position. These rings slip, and the ECU cannot reach the correct timing by actuating the solenoids. Usually, they slip due to VVT locking/unlocking vibration.
There is also the scientific approach with a pico-scope.
Old Oct 24, 2024 | 02:02 PM
  #39
Go0od question !
This is a sofisticated Mercedes....
-- It can runs both good and bad.
- good enough to go earn keep
- bad enough to hand over bundles at MB specialist
VVT rattle when unlocked but then get in position given pressure.
In fact we can have you do a little free experiment to save $1k with zero parts.
Run solenoid MOD-3 with good oil + good pressure.
This should provide much needed pressure to prevent timing code.
The poor oil pressure is what's wasting the VVT lock pin... cleaver Mercedes!
Thats why you want free MOD-4.
Old Oct 24, 2024 | 02:19 PM
  #40
Tdavid1's Avatar
You guys think I can do this in the garage? I’ve done multiple Toyota and Honda timing chains but these cars scare me
Old Oct 24, 2024 | 02:23 PM
  #41
options are
You have worked on the best engines already.
then you are overqualified.
These cars are extremely well built to be serviced.
you won't need to drop V6 engine.
Here its NOT whole timing cover out.
If you want new VVT Gears...
it's injectors/HPFP/Valve cover out and
then again you can bump up oil pressure to normal levels.
Will cost you zero and save time.
+++ the only thing is... beware of aluminum bolts
MB likes the "one-time use" fasteners torqued to yield...
aluminum is 2-fingers tight.
+++ PCV Included
when removing HPFP...
Do the PCV with plastic breather line.
+++ Vacuum pump chevk-valve...
on the rear of bank2 exhaust cam you will find vacuum pump with a bad $5 check valve awaiting for your attention.
Old Oct 24, 2024 | 02:34 PM
  #42
JCM_MB's Avatar
With the help of the W212 group, you can nearly disassemble the whole car and put it back together if you have the time and patience.
However, you can first try @CaliBenzDriver 's suggestion of disconnecting the oil pump solenoid for a few hours, delete codes, rescan, and see how it changes. Just be careful you may get addicted and not be willing to put it back . You then decide if you want to dive deeper into other details.
Old Oct 24, 2024 | 02:42 PM
  #43
He needs viscosity pressure to position his loose VVT early.
MOD-1 definitely but above thin stock...
Thin stock is what causes low pressure to wear VVT pin.
Start with JC's excellent Motul 5w40 (it's far better than thin stock oil sheared as 10w30).
I can't recommend him to skip to 5w50 on 100kMi engine rings though that's what's needed to position VVT at idle without any VVT replaced.
Old Oct 24, 2024 | 02:43 PM
  #44
Tdavid1's Avatar
+++ PCV Included
So the whole timing cover doesn’t come off? So I’ll be removing valve covers and mainly changing the cam adjusters along with the small things while I’m in there? How many adjusters do I replace and how can I tell which one is bad? They’re pretty expensive..
im confused.. what would cost me zero and save me time?
Old Oct 24, 2024 | 02:49 PM
  #45
CHECK EVIDENCE before deciding
+++ PCV Included
that's when you start firming plans...
DE cars eat parts!
US cars drink gas!
JP cars drive Miles !
All based on Bosch engineering goodness.
+++ Still not checked yet ...
before rushing into Intake VVT job...
Check that VVT gears pins are unlocked
or CPS are telling jokes to ECU.
or both VVT+ CPS.
We are trying to minimize your efforts not inflate the tab.
Old Oct 24, 2024 | 03:00 PM
  #46
Tdavid1's Avatar
DE cars eat parts!
US cars drink gas!
or both VVT+ CPS.
How do I check the VVT gear pins?
Old Oct 24, 2024 | 03:05 PM
  #47
the free no-parts option uses proper oil pressure to hold VVT gears at idle without using the lock pins... presumed bad in your intakes (need visual check).
The M274/6/8 engines use a clever pump solenoid to disable half the oil pressure below 3500.Rpm
When you unplug pump solenoid, engine is allowed to run on normal oil pressure that can then be increased by way of viscosity to offset the "under rev'ed" pump.
Here MB uses a low Max pressure of 60psi while GM uses 90Psi. The oil pump has lazy output to "save gas".
You can turn that around with better viscosity in the W50 range.
Beware your 100kMi piston rings are jammed with soft carbon from gallons of burned oil deposits.
Feeding 10W50 directly without any cleaning steps *may* help cause LSPI self-ignition piston damage.
Normal oil pressure remains a valid experimental option with working VVT a lot of us are using. You don't need bad VVT... in fact good VVT's benefit from not overworking lock pins with reduced oiling.
Old Oct 24, 2024 | 03:08 PM
  #48
Tdavid1's Avatar
This M276/8 uses a clever pump solenoid to disable half the oil pressure below 3500Rpm
When you unplug sokenoid engine is allowed to run on normal oil pressure ypu can then increase with viscosity to offset the under reved pump.
Here MB uses lower Max pressure of 60psi while GM uses 90Psi. The oil oump has lazy output.
You can turn that around with better viscosity in the W50 grades.
Beware your 100kMi piston rings are jammed with soft carbon from burned oil deposits.
interesting… would that help my misfire/out of time as well?
Old Oct 24, 2024 | 03:09 PM
  #49
Jaybird123's Avatar
My m278 Bank 2 (passenger side US). I only replaced the intake adjuster (right side one in picture, nearer center of motor)
Old Oct 24, 2024 | 03:11 PM
  #50
Jaybird123's Avatar
How do I check the VVT gear pins?[/QUOTE]
If you manually rotate engine by crankshaft, you will hear/see a click and a jump if the VVT gear is faulty. You will know it when you see it, and there are videos online too
