Sponsored by: CARiD
Does the rear diff oil need to be changed?
Old Oct 25, 2024 | 07:50 AM
w204benz's Avatar
Mercedes C Class (W204)
Question Does the rear diff oil need to be changed?
Hi Folks,
So I picked up my Mercedes W212 around 6 months ago with 60k miles, it's a 2.2 diesel. I couldn't find any paperwork for the rear diff oil being changed in the past so I called up my local MB dealership to get a quote and they have told me that the rear diff oil doesn't need to be changed unless it's the AMG model? (E65 etc) is this correct or are they having me on?
Old Oct 25, 2024 | 08:34 AM
W205C43PFL's Avatar
Originally Posted by w204benz
Hi Folks,
Yes, you need to eventually change it. It is mentioned on WIS, that said this example is based on a W205 not the W212. The front diff was not mentioned on WIS however would recommend changing the fluid as well. I think the more important thing is having the transmission fluid changed if it haven't already been done. That does wonders for the shifting quality and to prolong the life of the transmission.
Last edited by W205C43PFL; Oct 25, 2024 at 10:53 AM. Reason: Realized there were several typos
Old Oct 25, 2024 | 10:27 AM
shertex's Avatar
1991 300D, 2006 E320 CDI, 2014 E250 Bluetec
I think it's a good idea to change at around your mileage. Rear is easy to do. Is yours a 4Matic? Front diff fluid is a little more challenging (there is no fill hole on mine) but very doable.
Old Oct 25, 2024 | 11:49 AM
w204benz's Avatar
No so mine is just normal RWD and not the 4matic. I’ll speak to an individual garage and see if they can do it instead since the main dealer doesn’t want to do it
Old Oct 25, 2024 | 11:50 AM
w204benz's Avatar
Thanks for your reply, so I’ve actually just had the transmission oil changed recently so I’m just looking to get the rear diff done now. I’ll contact a garage in a few days and get them to do the rear diff oil change.
Old Oct 25, 2024 | 12:15 PM
W205C43PFL's Avatar
Sounds good.
Old Oct 25, 2024 | 12:19 PM
Sunnyslope48's Avatar
2016 E350 Sport 2WD
Well, that's what they say. HOWEVER, fresh fluid of the correct spec will never hurt anything and removing the old fluid may allow you to see problems within the differential if there are any. I changed mine at 60K and it wasn't much of a job.
Old Oct 25, 2024 | 12:55 PM
Pantomime's Avatar
2016 E350 Sport
Do you mind letting us know how much you paid for tranny service, just to get an idea because I'll need to get mine done soon? And was this a dealer service? Thanks.
Old Oct 25, 2024 | 05:34 PM
pierrejoliat's Avatar
24 GLS580 '23 E450 4matic 12 E350 4Matic
I had the front and rear differential oil changed at 55k and again at 102k when they did the transmission services, tranny service was 400 the second time and 100 to do the front and rear diffs.
Old Oct 25, 2024 | 06:03 PM
JettaRed's Avatar
Veteran: Army
Probably between $600 and $700. Your dealer may let you bring your own parts and you just pay the labor. Mine did. The tech confirmed all the parts were genuine Mercedes. The fluid was Pentosin/Fuchs, which I believe is OE for Mercedes.
Old Oct 25, 2024 | 06:06 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
FIX DIFF. GLITTER GAME..
Hi Folks,
There's no service to replace Diff. oil... the service is to replace whole differential + 1Qt of 75w90.
I did my RWD diff. at 50kMi...
oil was in good condition but...
loaded with fine glitter from soft gears
So I invested in a neodymium diff. plug.
Problem cancelled!
Old Oct 25, 2024 | 06:08 PM
JettaRed's Avatar
Veteran: Army
Sounds good.
The fluid is 75W85 GL5, though FCP will show 75W90 fluid, as well. The fill plug and drain plug use a 14mm hex socket.
https://a.co/d/aiWWN1R
Old Oct 25, 2024 | 07:49 PM
special plug style
the differential fill/drain plugs have no washer seal... instead a self-sealing tapered cone shape is used.
Old Oct 25, 2024 | 08:29 PM
W205C43PFL's Avatar
https://cimg6.ibsrv.net/gimg/www.mbw...9554d2e61f.png
Good info for OP thank you : )
Old Oct 25, 2024 | 11:01 PM
Quint22's Avatar
Veteran: Navy
2014 Cummins, 2014 E250 Bluetec
For some unknown reason the stars aligned and MB decided the rear diff was going to be as simple as every other rear diff to change fluid in. Its pretty amazing but true. They actually put fill and drain plugs on it that are somewhat easily accessible. Follow cali's advice and get a magnetic drain plug if possible.
On my om651 e250 4matic I changed both front and back at 105k miles, front looked like engine oil (used), rear looked basically brand new. Didnt have it tested though.
Old Oct 28, 2024 | 05:16 AM
w204benz's Avatar
Yeah so I am based in the UK and it cost me around £320 I think it was at the local MB dealership.
Old Oct 28, 2024 | 05:18 AM
w204benz's Avatar
Yes, I am based in the UK and it cost me around £320 if I am correct. (sorry forgot to hit the quote button to reply)
Old Oct 28, 2024 | 05:21 AM
w204benz's Avatar
Is your car a 4 matic?
Old Oct 28, 2024 | 06:43 AM
Dave Backmarker's Avatar
2018 AMG GT S, 2016 E350, 2013 GLK350
The main dealer does not want to change the oil in a rear diff? I would definitely not return to that mechanic. This is a very easy procedure. It took me less than a 1/2 hour.
Old Oct 28, 2024 | 09:45 AM
S-Prihadi's Avatar
You can DIY diff oil change and messy-free when filling..... Here : https://mbworld.org/forums/e-class-w...il-change.html
Old Oct 28, 2024 | 11:17 AM
Yes, weird though, both times the front was dirtier than the back, I have no clue why
Old Oct 28, 2024 | 02:10 PM
Pierre, the front has a much-much harder life than the rear....
Front axle chews up bearings routinely, the rear never does.
I believe this is caused by the wheel RPM differences.
Old Oct 28, 2024 | 08:18 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
and universal joints as well.
Old Oct 28, 2024 | 10:15 PM
Quint22's Avatar
Veteran: Navy
And .6 liter oil fill....
Old Oct 29, 2024 | 09:32 AM
W205C43PFL's Avatar
I wonder if it also has to do with the engine is in the front and that is heavy?
