Brake Pads Thickness
Usually the rear pads are smaller and/or having lower thickness to even up the wear, but lot depends on your driving style.
Modern pads last very long time and are cheap enough to not to worry about disposing one end prematurely.
Just check your rotor thickness at the time and compare to min stamped on it.
Rotors can last about 3 pads sets, but they develop lips, who might need some grinding.
You really need to drop wheel to inspect individual pads.
Front rotors need to go anyway even they can well be resurfaced... the surface heat treatment hardening is shot so best to replace them.
If you have the multi-piston calipers then pads may wear more evenly.
Also the smart ESP lane keeping advanced features wear wheels differently by axle....
things have changed since this that was true...
obviously heat treated 🥱
The hardness of rotors and pads is critically matched to get specific friction, temperature and durability.
Without heat treatment high carbon steel rotors would be too soft... so indeed brake rotors are heat treated as quoted above.
Also the various heat treatments of said Cast irons:
CastIrons.pdf
My issue is who knows what was specified by MB engineers for rotor material?
Love to see a manufacturing drawing.
When cast iron treatment is different from steel treatment and they have different goals, seems new technology brought the term to cast iron.
Reading more about it, the treatment removes carbon from cast iron surface.
Found a manufacturer, who claims to be "advanced" rotors manufacturer, who goes opposite way. They put more carbon for better performance
https://shopdixcel.com/products/dixc...e-brake-rotors
For me rotors are like 1/2 millions miles item, so there is no way I will be ever able to compare.
If you don't know the history of the car, then resetting the brake system with new pads, wear sensors and rotors all around, as well as new fluid will put you in a good position for the future. The advice about uneven wear noted above shouldn't be dimissed.
On the other hand, if you know you are going to replace the rotors anyway, then heck, go ahead and run the pads down to the metal. LOL, this is my cheap way of getting the most from my fronts, where I just recently started hearing the wear-indicator squeal, but I'm gonna get new rotors anyway so why not get more free miles. Car has around 122k so I think yeah, pretty dang good!
Edward
Edward
https://a.co/d/8PUVm4g
