Sponsored by: CARiD
Problem with starter E350 OM642
Old Dec 4, 2024 | 01:30 PM
FilipKitanovski's Avatar
Hello, I have a problem. When I start the engine without waiting for the ignition to turn on, it starts normally, but when I wait 5-6 seconds for the ignition to turn on, it just clicks and doesn't start.
What would could be starter or EIS
Old Dec 4, 2024 | 01:55 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
V6Diesel
...you mean glow plug control, not EIS
Use a $150 Launch MB scanner to read chassis faults, then you'll know.
Could also be a relay in the front fuse box (fSAM).
Old Dec 4, 2024 | 02:08 PM
When I start the car, the glow plug stays on for a while and then goes out.
Old Dec 4, 2024 | 04:20 PM
Isn't this the normal startup sequence for this engine??
Old Dec 5, 2024 | 09:32 AM
S-Prihadi's Avatar
Get a current clamp and a voltmeter.
Read the voltage and current consumption during :
01. Immediate crank to start
02. Ignition ON for 5-6 seconds and then crank.
The glow plug heater needs lots of power, easy 100 watts each cylinder.
So if your battery is weak, by doing 5-6 seconds wait, the battery amperage drain could be high enough to render no more enough CCA for the starter which will need
peak about 600ish amps for first 1/4 to 1/2 second of cranking from zero crankshaft speed or zero starter speed.
Typical cranking with starter already spinning is about 220 Amps for my 6 cylinder petrol engine.
