Time for new tires
Open to suggestions of other tires to consider-
Thanks!
Thanks!
2. I have run two sets of Conti ControlContacts (from America's Tire/Discount Tire) and they are great! Excellent grip, good in the wet, stay quiet as they age, and their mileage warranty pays off at the end of their usable life. I'll do it again without hesitation at the next change.
Edward
Edward
Post #5 is blunt but accurate.
quick example:
now, if by inside, you mean one side of the tire is wearing more than the other side, you have an alignment issue.
The previous tires were new when I bought the car 5yrs ago, I only replaced them due to cracking, the tread was still ok.
I have always been buying the lowest price tires with good reviews for all previous cars. Never had a flat, never needed a tow truck, never drove off the road due to tire issues.
Tire prices are crazy now a days like everything else. My truck which I run 295/70-18s ST MAXX which I can get 75-80K miles out of use to cost $850 a set when I bought my truck, now they cost about $1800 set.
To the OP, I had conti tracs on my car when I got it, they were end of life but still performed good. I put cheapo tires on Laufenn S FIT AS on and although they perform well in wet weather and all that they have weak sidewalls and as such do not handle nearly as well as the conti tires did. Will see if I can get the 40k miles out of them. They are wearing evenly even without properly rotating them like I should. I keep them at max pressure where the conti's I ran about 5-10psi less than max for a little better ride. Just my experience.
Edward
different size tires are designed for different vehicle sizes. The W212 is a fairly heavy car (GVWR of my wife's wagon is 5721 lbs, 2600 kg) and specifies XL (extra load) tires, eg 245/45R17XL or 245/40R18XL, and these are only available in specific sizes.
all tires, after the size, like 245/45R17XL, is a load and speed factory, like 99Y ... Load Index 99= 1,709 lbs (775 kg) per tire, Speed Rating “Y”= 186 mph (300 kph) (ok, "Y" is excessive for a E350, "V" would be plenty).
