Sponsored by: CARiD
Battery drain issue?
Old Dec 31, 2024 | 02:19 PM
cdnswede's Avatar
2003 clk 320 / 2015 B250 / 2016 E 400 Estate (wagon)
Car : E 400 2016 (W212 facelift) station wagon (Estate) in Canada. Approx 188k km.
New recurring problem.
September : Had to replace battery as the car needed to be jumped to start. It may have been the original MB battery (car acquired in 2019). Battery replaced (not OEM).
December : Out of the blue, car would not start. Needed to be jumped again (2.8 volts). Starter would engage, the fuse had blown, possibly due jumping or cold weather that day (-18 C).
Battery replaced again (not OEM) under warranty. Mechanic confirmed that alternator is OK. Instrument cluster message of faulty auxiliary battery, so had that changed with OEM auxiliary battery.
Within the week, car had to be jumped again (4.1 volts).
It could be a coincidence, but both times in December, the car would not recognize the key and I had to remove the Star/Stop button to crank the car a few days before it needed to be jumped.
Either I am unlucky with the not OEM batteries or there's a drain on the system.
Is this something that is known to have happened to others?
Old Dec 31, 2024 | 06:30 PM
cdnswede's Avatar
Thanks for the response! What is a CAN tool?
Old Dec 31, 2024 | 07:24 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Facelift W212 has developed an appetite for new batteries.
> SHORT TERM :
-- prevent low voltage with a CTEK automatic charger
-- use a jump pack to never be stranded away
> LONG TERM :
-- Seek repairs from an independent MB specialist
I would not be surprised when you confirm this was related to water damaged module.
Counter measures will help make this drama less disturbing and cheaper to address.
Old Dec 31, 2024 | 07:51 PM
ChuangTzu's Avatar
19 GLA45, 86 560SL, former: 14 E550 4Matic, 09 E350 4Matic, 83 240D manual, 78 450SLC, 81 500SLC
I noticed when I got the car earlier this year that it had an interstate battery made in 2013 in it. My car was made at the end of 2013. Not sure how that happened, but I have no complaints about its longevity.
Old Dec 31, 2024 | 08:03 PM
luck of the draw
You are very lucky!! 👏
Some chassis got no battery issues
some are remarquable battery hogs...
Drained by Parking...
Drained by Driving...
Drained both by driving and then by parking!
likely due to the R-SAM reporting voltage to ECU through CGW.
The variable ALT voltage is nothing but useless drama... >>> unplug ALT LIN!
Old Dec 31, 2024 | 08:43 PM
ChuangTzu's Avatar
What modules are particularly prone to water damage?
Old Dec 31, 2024 | 09:16 PM
The main modules setup to be water damaged are both rear radars and then the Front SAM from roof/windshield leaks.
Besides every module can get disrupted through soaked CAN distribution bars at the footwell door-threshold area.
To identify use favorite troubleshooting tool & procedure to pin point short list.
Old Jan 1, 2025 | 10:38 AM
Arrie's Avatar
What are the voltages you post? During trying to crank or just measured without trying?
Old Jan 2, 2025 | 03:07 AM
S-Prihadi's Avatar
Start confirming how bad is the battery drain.
Read here : https://mbworld.org/forums/e-class-w...-your-car.html
At the least isolate the module/wire being responsible is at Circuit 30 or Circuit 30G ?
You do not need a scanner for this for tracing ( but needed for DTC reset ), for now.....
just patience and fuse list table of front SAM and rear SAM and F32.... they are fuse boxes too and the front SAM has sensitive electronis in it.
Wiring diagram for alll 3 "fuse boxes" I mentioned will be good. I can help you with all these.
You must have the DMM with 10 amps and 400 milliamps capability and the jumper cable I speak of, to save your DMM fuse from blowing up.
If you have DC current clamp, it will be very good too...but not super important for low power drain.
Old Jan 8, 2025 | 07:43 PM
cdnswede's Avatar
UPDATE :
Hi all. I left the car with my mechanic for a few days (including the week-end). He had two mechanics with an expertise in car electronics go over the car (approx 4 hours between the two of them) for diagnosis. The only conclusion that all could come to, is that when the engine start/stop button is in the ignition, there is a large amp draw which drains the battery. When the button is removed, there is no abnormal current draw. The car was left over the week-end without the engine start/stop button and it was able to start on Monday. I brought the car at home and left outside (average temperature is about -10 C) and the car cranks since then. I will keep testing for the rest of the week.
Old Jan 8, 2025 | 09:01 PM
push to start button out
UPDATE :
I hope this help a bit your KeylessGo module...
When the car security is locked the ignition module is inactive.
