[HELP] COMAND screen does not turn on
radio/audio/volume works fine.
is display unit dead or is it something else?
is there a way to reset COMAND and hopefully screen will work again? TIA!
Might not be too big of a deal...
Use your scanner to interact with DISPLAY module and collect live faults.
Is a better way than parts-canon then troubleshoot afterwards.
Display is a SUPER HOT MODULE that uses a dedicated fan cooling with a tiny filter.... that gets plugged shut.
++++ @MJ50 WHILE YOU'RE HERE....
CAN YOU PLS HELP THIS FORUM!
A -> HOW TO best deal with bothersome trolls ??
B -> HOW MANY user petition complaints does it take to cut access of sickos ??
C -> HOW ABOUT banned accounts that swap UserID's to resume activities??
Thank you from a bunch of us.
b) there's no set of numbers, but the more you "report", the higher the likelihood...
c) same as (B), the more you report, the better...
