Sponsored by: CARiD
Power steering issue 2014 e350 - no error message on dash
Old Feb 11, 2025 | 12:53 PM
Tommy23B's Avatar
2014 E350
My 2014 E 350 4-matic has started straining when I turn the wheel 70 to 100%. in parking or tight quarters. not on the road at speed. My first thought would be to check the power steering fluid level. Did not find a power steering fluid reservoir and saw something online that this car has “electronic power steering”. The car only has 65,000 miles on it so I'm hoping it's not the rack and pinion. Anybody had similar problem and what did you do to solve?
Old Feb 11, 2025 | 12:55 PM
W205C43PFL's Avatar
https://mbworld.org/forums/e-class-w...s-modules.html
Old Feb 11, 2025 | 08:12 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
SAFETY INVOLVED
What lays in the balance is an 8,000.USD repair... hopefully dealer will locate rebuilt rack inventory to perform the repair.
You will want to get your EPS evaluated for fault codes and ensure proper stable chassis voltage is available.
These fancy 3Phase 12VDC rack uses built-in solderless connections that help disruption.
Old Feb 11, 2025 | 08:15 PM
degeja's Avatar
2016 E350 Sedan SPort
I traded
Old Feb 12, 2025 | 08:27 AM
S-Prihadi's Avatar
Explain in detail this : My 2014 E 350 4-matic has started straining when I turn the wheel 70 to 100%.
Do you mean your engine RPM bogged down or what ?
By 2014 model it must be electric power steering and not hydraulic one.
Old Feb 28, 2025 | 12:46 PM
Tommy23B's Avatar
2014 E350
Yes, electronic power steering. But no the RPM's didn't go down it was a “shudder” the best way to describe it. What has happened since then is I took it to the dealer and they told me it was the transfer case clutch pack failure. Or a fault code for that. They want 3259 dollars to fix it - to replace the clutch pack in the transfer case. I'm going to make a separate posting asking questions about this issue.
