Sponsored by: CARiD
Choppy Tires
Old Jun 25, 2025 | 02:04 PM
cooky01's Avatar
E350
Question Choppy Tires
My front tires appear to be choppy, w/ the passenger side more severe then the driver side. (see image)
Did a wheel alignment at Les Schwab, and they said the wheels are straight & aligned.
Anyone know what else would cause the tires to be choppy?
My E350 is RWD, and the front tires typically don't wear out as fast the rear ones, so this is a bit of a surprise to me.
Old Jun 25, 2025 | 02:09 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
I've done that by driving aggressively with directional tires mounted incorrectly (they were turning backwards).
Old Jun 26, 2025 | 02:03 AM
ygmn's Avatar
2015 E400 Sedan
bad shocks can cause tire issues.
Bad road surface.
I would replace.
PS not much tire alignment they can do other than toe.
Old Jun 26, 2025 | 11:34 AM
Senecat's Avatar
1983 Nissan Shltbox
What is the date code?
Old Jun 26, 2025 | 01:13 PM
cooky01's Avatar
E350
Thank you all for your responses.
Front tire date codes are: 6JP0622 & 6JP1822.
I bought them in November of 2023, so at the time of purchase they were ~1 year old, and they're now 3 years old...
Old Jun 26, 2025 | 05:25 PM
Senecat's Avatar
1983 Nissan Shltbox
Tough to say. How many miles on them? What manufacturer?
Old Jun 26, 2025 | 05:58 PM
cooky01's Avatar
E350
~25,000 miles
Yokohama ADVAN Sport A/S+
Old Jun 26, 2025 | 06:01 PM
Senecat's Avatar
1983 Nissan Shltbox
Wow, so those are good tires with not a ton of miles on them. I don't what would cause that, but thanks for the info. I'm just as intrigued as you. I hope we come to a conclusion here!
Old Jun 27, 2025 | 12:29 AM
BenzV12's Avatar
W212 FL
Another thing just cross my mind is that a wrong tire pressure possibly but inner threads are worn out faster as far I know that when it happens
Old Jun 27, 2025 | 07:50 AM
juststeve's Avatar
2012 E63 Wagon
This manufacturer must have designed the tire with a special thin outer layer of rubber compound to save money. Looks as if you have begun to wear though that outer layer of rubber at those outer edges. Won't be long before that layer begins to come off in larger chunks and sheets. You may consider another manufacturer once you address the cars alignment.
Old Jun 27, 2025 | 08:00 AM
hyperion667's Avatar
2012 CLS63
That's a lotta miles huh? Perhaps get them replaced with a prorated discount applied.
Old Jun 28, 2025 | 06:33 AM
S-Prihadi's Avatar
Check the tire year of manufacture.
I seen a 6 or so years old, good brand tire has its sidewall broken off, due to age.
Yep, its like brittle rubber, BROKEN into pieces it did.All air is lost.
Inspect in detail the side walls innner side and outward side.
Old Jun 28, 2025 | 09:21 AM
dmatre's Avatar
Had: 1987 300TD, Had: 2004 C230 Sport Sedan, Have: 2014 E350 Sport, Have: 2019 S450
I had a similar condition on a tire early in my driving career (45 years ago)...
The problem was my driving rather than tires/pressure/alignment.
I was swinging into my parking spot at full lock at speed, which very quickly ground the outside shoulder off (and could chunk like that if there is sand/stone/gravel present).
At that age, replacing a tire was a significant expense, so I slowed down, and the next set of tires on the same car lasted around 30k miles with no outside shoulder wear/chunking.
Don't know if this is the issue with your tires, but it's what happened to me.
