Sponsored by: CARiD
dreaded oil in ECU?!?!
Old Jul 1, 2025 | 12:41 PM
Klause's Avatar
W212 2012 E350 wagon
🙏🙏Hi guys! I replaced my beloved W210 wagon with a newish w212 wagon (100K miles). I've experienced a slight engine hesitation "misfire" that occurs intermittently under light engine load / driving up gradients. It's usually hardly noticeable, but more pronounced in occurrence / severity in warm temps (80f plus). I can usually trigger it by increasing throttle from 1800-2000 rpm / 70mph up a slight incline on the highway. Engine will slightly "buck", increasing throttle a bit more will stop symptom. Otherwise car ran flawless. I changed spark plugs & coils w/ oem parts, good times!! Is it just an afterthought from engineers that you might have to service this car someday lol !?!? Anyways, no change in symptom. Sidenote: Upon plug/coil install, I noted scant oil in the air intake assembly around throttle body. I cleaned it up, not much new oil occured there in 7K miles. I understand this is not ideal, but tolerated w/ this engines PCV design. I see a catch can install in the future. I also had the transmission serviced for giggles, again no change. Lately, this "misfire" became more pronounced as weather got hotter, so I decided to address the cam position solenoids & position sensors. I had noted slight oil around those units a year ago. I ordered the sacrificial pigtail kit w/ sensors from FCP euro, hoping maybe this was my "misfire" issue. I was only able to replace the passenger side solenoids, sensors, and pigtails. Driver side had to wait due to intake manifold removal required / new intake gaskets. When I unplugged cam position sensors, both had significant oil noted in connections (no oil noted in solenoid cam sensor connection). Cleaned them out w/ the kits provided electronics specific cleaner spray. Allowed to airdry / hit w/ air gun. I assessed electrical connections downstream from noted oil in sensors, and found damp shiny residue in the ECU connection. Despite my instincts, I sprayed provided electrical cleaner in female ports & ECU male ports while upside down & allowed them to drip face down. Air gunned them prior to reconnect. On test drive post battery reconnect, I threw about 10 codes (P2088,0010,0300,0301,0303,0302,0113,0098,0108,213 7) & car quickly went into limp mode. YIPEEEEE!! I have assumed I introduced oil into the harness connection, possibly inside, the ECU. It was likely there already, but I may have forced it to new critical places? I have soaked the the connections in 91% alcohol, tried various electronic cleaning sprays & ensured more airdry time w/ fans etc. No change except for new codes. I haven't opened the ECU, but do anticipate sending it off to be assessed / tested (recommendations for referral?). Sorry about the LONG thread, wanted to be thorough. I'm trying to trouble shoot & reduce my impending mechanic / shop bill. THANK YOU VERY MUCH for your time!!!!
Old Jul 1, 2025 | 02:44 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
OIL LEAK 10K-HARNESS
Welcome to the W212 party - Well help you stay on the road!
Can you pls decipher the trouble codes you're interested in with what status: "stored/active" ?
BTW did you disconnect your AUX Batt when MAIN was Off ????
Old Jul 1, 2025 | 05:13 PM
Klause's Avatar
Thks for responding! I did not disconnect the aux battery, hope that didn't contribute to this situation. The codes are noted in original post from initial scanner reading (P2088,0010,0300,0301,0303,0302,0113,0098,0108,2137 ). When I tinkered w/ car today & started it, it had a bad camshaft adjuster rattle that went away after a couple seconds. I'm assuming this is due to improper / no info going through computer to cam solenoid? Kinda concerned Im in danger of causing mechanical damage to engine now. Appreciate the help
Old Jul 1, 2025 | 05:30 PM
Klause's Avatar
Per my scanner, codes are not permanent. I clear them, unhook battery, scan to confirm still clean, start car & it throws codes again & goes into limp mode. Most recent engine start resulted in loud rattle from cam adjuster. Guess cam solenoid is receiving wrong / no signal maybe? Concerned I'm gonna cause mechanical damage etc.
Old Jul 1, 2025 | 05:33 PM
more fault info
Besides what was written earlier...
your "startup rattle" is existing mechanical defect of intake VVT.
Do repair the rattle ASAP before it turns into "correlation faults" them you'll need camshafts replaced.
Camshaft positioning solenoid have nothing to do with startup rattle. It's caused by unlocked VVT gear(s) worned out by stock limited oil pressure.
Old Jul 1, 2025 | 10:44 PM
Klause's Avatar
OK. I'm aware of VVT issue w/ these engines. I have noted very mild valve "chatter" on start up / especially cold days. But never this pronounced. Just figured it tied into my related cam sensor codes & suspect electrical issues.I feel like I need to address electrical connection prior to chasing down the mechanical cam VVT potential issue. Tempted to send off ECU to a specialist to assess if its compromised / oil inside.thks again
Old Jul 2, 2025 | 02:54 AM
"Harness-oil" at ECU + "startup-rattle" are TWO unrelated issues.
--1-- if you decide to get your ECU repaired then you will want to install an oil-free harness.
--2-- The rattling will need troubleshooting to survey damages: tensioner, intake VVT, camshaft
Old Jul 15, 2025 | 10:21 PM
ostmcaleb's Avatar
2010 E350
any resolution to this issue? I think I may be experiencing the same thing.
thanks!
Old Jul 15, 2025 | 11:15 PM
thanks!
you have already swapped your ECU. Are you also getting "VVT Rattling" now?
Old Jul 15, 2025 | 11:29 PM
ostmcaleb's Avatar
2010 E350
no rattling just weird idling, and misfires along with the same camshaft sensor codes…
very bizarre…
