Sponsored by: CARiD
E200 W207 SAM or ECU Issue
Old Oct 8, 2025 | 10:27 AM
Jxjxjx123's Avatar
Hi all,
I have problem with electronic on this mercedes
Car wont start or when it start have very bad idling and and have 8 dtc about random components is short to the ground.
When pull out K relay from Driver Sam and crank it,put back relay car start,idle and drive normaly ,dtc clears full
Ignition lock is fine,Can e distribbutor is fine 60ohm resistence and good connection with sam and modules
I dont have any morr ideas,please help
Old Oct 8, 2025 | 10:30 AM
Jxjxjx123's Avatar
Car have eco start stop and aux battery malfunction dtc
Old Oct 9, 2025 | 11:33 AM
Sunnyslope48's Avatar
2016 E350 Sport 2WD
Originally Posted by Jxjxjx123
Hi all,
Pls tell us the 8 DTCs. Must be a clue in there somewhere.
Old Oct 10, 2025 | 09:40 AM
Jxjxjx123's Avatar
Old Oct 10, 2025 | 10:23 AM
trigital's Avatar
W213 All-terrain
Chain stretched or Camshaft Variator if is not diesel may be tested
Old Oct 10, 2025 | 11:00 AM
Jxjxjx123's Avatar
But car running normal when i do cranking wo kN relay and start again
Old Oct 10, 2025 | 12:22 PM
2016 E350 Sport 2WD
The 3 current readings are what you would be concerned with. The other codes are what are commonly called history codes, codes that were there but are no longer active
Old Oct 11, 2025 | 05:33 AM
Jxjxjx123's Avatar
So you think thats timming related issue?
Old Oct 11, 2025 | 10:25 AM
2016 E350 Sport 2WD
That's what the car thinks. Google 'p001664 MERCEDES' and read up on that code and the others.
Old Oct 11, 2025 | 01:13 PM
Jxjxjx123's Avatar
But what is interesting is
wnhen car runing normal whole system measured voltage is above 14v(Sam,alternator,prefusebox)
and when is bad idle is 11.5v that what made me think this is el issue
Old Oct 11, 2025 | 01:41 PM
2016 E350 Sport 2WD
Check your battery voltage at rest, when the engine has been off for an hour or more. What is it?
