A Bad Water Pump Could Do That
Well, 11 years and 115K miles is a fair lifespan to me for a water pump.
I though I have to share my experience with you . If you see any message about coolant please don't ignore it
Do you want to do a comprehensive cooling tune-up or keep it short?
- cooling pump
- pump plastic inlet
- thermostat
- hoses upper/lower
- serpentine kit with tensioner
- (radiator!)
- (expansion tank + cap)
- (coolant/oil exchanger)
The engine heat accumulation is what's causing heat soak pressure may be seen by cooling fan running non-stop.
And, HOT chicks spreading their legs at me.....
> STOCK SETUP...
-- The thing about engine cooling is heat is not only moved by smallish water pump.
-- A lot of heat gets accumulated in pistons unless it is circulated out through the oil heat exchanger.
-- Meaning most of the engine heat is not in the water but in pistons.
-- After engine stop, the hot pistons boil off coolant -- Heatsoak pressure burst radiator seams.
-- New radiator can not accomplish much to tame heatsoaks.
Speaking of legs :
-- Paradox... Fan roaring in Winter with a hot engine that never seem to cool off despite all the cooling power !?!
-- To get a leg up you need to spray-cool pistons effectively at driving Rpm else heat accumulates.
Smart doggies... learn to rest on their back like they see us do 👏
- cooling pump
- thermostat
- hoses upper/lower
- (radiator!)
Thanks ,
I also talked about the thermostat but they said no need to replace it right now . We'll drive and see what's gonna happen . If I notice temperature fluctuations then thermostat is gonna be replaced too . We'll keep it short for now and hopefully will be enough to fix it
Anyway, a healthy coolant system should be able to cope with all these factors.
The car is running like new , no more coolant loss as well as a steady temperature but we smell a coolant leftovers that's not funny but these should be go away after a quick clean up lol
Thanks all
