Questions on my flex discs and shaft bearing job on my 2010 E350
I’m doing my flex discs and shaft bearing on my 2010 E350. I’ve owned this car from about 2012 and don’t believe this stuff has been replaced yet because I’ve never done it. Here is the state of things upon disassembly:
as you can see the boot that was mentioned by some on a previous post is missing. Could my model just not have had this originally? It’s pretty cheap I don’t mind throwing one on if I can make it fit but just thought I’d ask.
Inspection: how are your :
- Support bearings side play and
- U-Joints freeplay and
- Rear diff. input shaft bearing freeplay
- Front/rear slotted rubber flex disks
- At what mileage?
Is the level of vibrations on Hwy what guided you to prop shaf or scheduled overall maintenance ??
so the question I have is on the propeller shaft alignment sleeves. I’ve read in the service manual that these have a specific alignment depth, but the front sleeve in my car at this time is not at the recommended depth (approx 24mm vs 36.3 per the manual). So the questions I have are, do the alignment sleeves have to be replaced? Are they an actual wear item i.e. is it made of multiple parts with a rubber component or is it just a solid piece of metal? If they can and do wear how do I inspect them to determine this? If I do replace them, do I insert them to the same depth they’re at now or do I go by the service manual? Please see the pics for further clarification.
Mike
Mike
Do you notice signs of the drive shaft being worked on previously, besides the missing boot?
I was scrolling thru eBay at used W212 drive shafts and they seem to all have boots. At least the ones im seeing. Though there are a few different part #'s.
For the centering sleeve I see a note in the removal instructions about the specified insertion dimension may deviate... Not sure what that means exactly. But, if it were me i would leave it alone.
I did notice on the diff side there looks like a more pronounced wear ring on the shaft where the transmission side looks even. I wonder if there is an issue with the angle of rear section of the drive shaft? I'm purely speculation and just wondering.
I'm looking thru photos of used differentials and the wear, or lack or rust, looks different than on yours.
Could be normal. Just stands out to me.
Mike
This was the change in the “a” measurement that I mentioned before that I recalled seeing somewhere. Looks like it came out prior to my model year 2010 so maybe mine wasn’t changed? But this still doesn’t explain the difference between the “a” measurement in my car and the manual. Thoughts?
Mike
So if your car was manufactured prior it could have the old specs.
I dont see anything saying the centering sleeves should be replaced if they dont have the current specs. Usually would be a TSB and i'm not finding anything about it.
If you do replace them i'd use the specs you posted. I'm assuming you have the 212.056?
Mike
As long as the penetration of the male protrusion of the tranny side is long enough to maintain alignment ( with flex disc sandwitched in between ) of say 15mm insertion, it is good enough. 15mm is 0.59 inch.
Also get a better flat edge, dont use that distorted square ALU pipe. Get a JIC Class 1 measuring tape too or a caliper.
You also seems to not know inch to millimeters conversion
I am seeing the measurement is tilted, not only the inch to millimeters conversion is wrong.
ABOVE : Why you said it is 24mm when it is at least 28.58mm ?
BELOW : My eye ball is seeing 31.75mm, when and if you use proper flat edge and tape or a caliper.
The tape is cheap, for JIS class 1.Get TAJIMA brand. Its popular in USA too. Get millimeters version.
The dumb azz inches measuring tape increment is so bad at 1/8" which is 3.2mm, how can you use it for accuracy work demanding 1mm ?
The habit of reading/printing in fraction 1/8" ( 0.125 inch ) is wasting valuable space on an already small tape
.The millimeters line or increment is worth 0.039 inch, which I do not know the fraction value ...LOL , but it is 320% more accurate an increment over the inch measuring tape.
The front end ( tranny side ) of the propeller shaft would be similar to the rear end or DIFF side. Mine, DIFF side only.
Stay safe under the car............
The true alignment in the end are the bolts of the flex disc and how good is the new flex disc shape.
or
You buy new sleeve and make the measurement like what WIS stated, but do becareful if the sleeve too long, it may touch or hit the male protrusion of the tranny side too early, aka sleeve too long.
Do a proper simulated measurement, it is easy.
I'm assuming the fitting sleeves in the flex disks are just pressed in, not stuck to the rubber so they can spin with enough force.
When you unbolted the old flex disks did you have to hold the bolt from turning while removing the nut?
