E-Class (W213) 2016 - 2023
Bulletins 213
Old Aug 21, 2018 | 12:44 PM
  #51
konigstiger's Avatar
'71 Pinto
LI54.30-P-068430 JUL18 – 213.#88/#89 FEB 2017 to JAN 2018 display of suspension setting in head unit does not match actual suspension setting (switch is correct), update Air Body Control (SPC) software.
LI54.30-P-068427 JUL18 – 213 e63 winter tire speed limit is activated automatically, update ESP & COMAND control units.
LI82.85-P-068445 JUL18 – 213, 217, 207, 238, 222 info-call/S24H-call/MB Contact change of language setting at customer request. At cost manual change in HERMES control unit: Control unit for telematics services -> Adaptations -> Configuration -> Manual settings -> Language setting.
LI54.21-P-068464 JUL18 – 213, 217, 238, 222 surface cracks or scratches on touchpad, replace touchpad.
LI68.20-P-068649 AUG18 – 213, 238, 205, 253 frame surface removal of stowage box/ashtray, replace damaged frame with optimized part.
LI82.85-P-068647 AUG18 – 238 with code 531 & 808 without 058 Radio and Media contens are no longer displayed in instrument cluster, update COMAND SCN coding.
Service Campaign 2018010008 AUG18 – 2018 213, 222 digital & printed owner’s manuals may not meet production specifications, dealer will update. Approximately 8,366 vehicles affected.
LI05.10-P-068624 AUG 18 –213, 217, 222 with 177 engine erratic squeaking or ticking noise from area of belt or chain drive of engine, replace tensioning rails of secondary chain drive.
File Type: mp3
Old Aug 21, 2018 | 12:52 PM
  #52
dukester34's Avatar
none yet
how would I know if my car is affected ?
Old Aug 21, 2018 | 01:14 PM
  #53
'71 Pinto
Assume your questioning service campaign have dealer check VMI to see if your VIN is affected.
Old Oct 16, 2018 | 04:48 PM
  #54
'71 Pinto
Service Campaign 2018080016 SEPT18 – 2018 213 E63 front brake pads may not meet production specifications, dealer will replace pads. Approximately 4 vehicles affected.
Service Campaign 2018090002 SEPT18 – 2018 & 2019 213 & 257 (CLS) wheel bolts may not meet production specifications, dealer will replace bolts. Approximately 648 vehicles affected.
LI30-P-068840 SEPT18 – 238, 217 when actuating the cabriolet roof open or closed rear deck lid will freeze mid operation w/stored fault codes B251939 & B251739, open PTSS case (MB technical assistance). Top can be reactivated by manually renormalizing rear windows using window switches - pull the button until the window has closed and hold the button for an additional several seconds.
LI88.40-P-068899 OCT18 – 213, 238 due to tolerance variations hood catch may not appear to be engaged causing “Hood Open” fault message, modify stop buffer and lock striker.
LI77.31-068900 OCT18 – 238 & 205 Cabrio with less than 1000 miles white faded stains on canvas, attempt to clean with MB cleaner 001986337110 if this fails replace canvas.
Old Oct 16, 2018 | 07:02 PM
  #55
teksurv's Avatar
2024 EQE 500
Thank you konigstiger for continuing to post this useful information. I've followed your contributions from 204, to 212 and now 213/238. Thanks again.
Old Nov 13, 2018 | 12:45 PM
  #56
'71 Pinto
LI82.85-P-068902 OCT18 – 2017 213, 238 w/code 531 (COMAND) audio volume during navigation announcements nonfunctional, software update expected 3/2019.
Old Dec 18, 2018 | 04:50 PM
  #57
'71 Pinto
Recall Campaign 2018100004 NOV18 – 2108 213, 257 passenger seat occupant classification system might not function as specified, dealer will replace the passenger seat cushion. Approximately 345 vehicles affected.
Recall Campaign 2018110002 NOV18 – 2018 213, 205 incorrect cover for the starter battery may have been installed, dealer will replace the battery cover. Approximately 4,073 vehicles affected.
Recall Campaign 2018120002 DEC18 – 2019 213 wagon the spoiler on the tailgate may not have been fastened according to current production specification, dealer will rework. Approximately 16 vehicles affected.
Old Jan 21, 2019 | 03:02 PM
  #58
'71 Pinto
Recall Campaign 2018120010 DEC18 - 2018 238, 205 coupes mechanical connection between steering wheel and steering rack might loosen, dealer will check and lock. Approximately 2 vehicles affected.
Old Mar 20, 2019 | 06:59 PM
  #59
'71 Pinto
ECU software warranty is extended to 10 years / 120,000 miles, see attachment.
Service Campaign 2019020014 MAR19 – 2019 156, 213, 217, 222, and 257 some printed materials may not have been supplied. Dealer will add for the affected vehicles. Approximately 211 vehicles affected.
LI54.30-P-069433 FEB19 – 2018 & 2019 205, 213, 217, 222, 238, 253 with code B01 (48 volt technology) instrument cluster does not show a welcome image, animation is disabled by design.
LI82.85-P-069555 MAR19 - 2017 213 w/531 upon opening the door a high-frequency whistling noise may be heard sporadically for approx. 5 seconds, under analysis see attachment.
File Type: pdf
File Type: mov
Old Mar 21, 2019 | 06:08 AM
  #60
stephos's Avatar
MY19 E450 4MATIC Coupé
good to know - thanks for the update!
Old Apr 23, 2019 | 10:35 AM
  #61
'71 Pinto
Recall campaign 2019030012 MAR19 – 2019 213, 257, 238, 205, 463 reset in the Central Powertrain Controller (CPC) control unit could occur while driving due to a software error. If the reset occurs during ECO Stop the engine will not restart as intended. In addition, vehicles could coast due to engine stalling. In this case the engine can be restarted while coasting. Dealer will update software. Approximately 127 vehicles are involved.
Field measure 2019040006 – 213 correct torque screw connection starter wiring harness to busbar (Nm 17).
Old May 24, 2019 | 02:06 PM
  #62
'71 Pinto
Service Campaign 2019040031 MAY19 – 2019 238 Pirelli P7 Cinturato tires 245/45 R 18 100 Y installed as original equipment d fail to conform to the maximum permissible inflation pressure marking requirements dealer will replace to Pirelli P7 Cinturato 245/45 R18 100Y XL MOE. Approximately 40 vehicles are affected.
Service Campaign 2019040010 MAY19 – 2018 & 2019 213, 253 installed stone chip guard may allow stones to contact the radiator dealer will retrofit a protective grille. Approximately 3104 vehicles are affected.
LI82.85-P-069789 MAY19 – 213, 238 with codes 531 or 506 some webpages using the head unit browser message "Fault during authentication" shows. Operating system only supports TLS1.0 encryption newer encryption methods cannot be shown on the head unit's internet browser.
Old Jun 25, 2019 | 01:08 PM
  #63
'71 Pinto
LI80.61-P-069910 JUN19 – 213, 222 Keyless-Go/Keyless-Entry (code 871) hands free may be nonfunctional or functional after several clicks, install HFA control unit part # 1679050200 or successor then perform SCN coding.
Old Aug 1, 2019 | 02:25 PM
  #64
'71 Pinto
Service Campaign 2019060002 JUN19 – 2019 213, 238, 257, 290 torque at bolt 8 between the automatic transmission and transfer case might not correspond with current productions specifications. It is possible that noises may occur during vehicle operation, dealer will replace and torque bolt. Approximately 131 vehicles are affected.
Old Aug 26, 2019 | 05:45 PM
  #65
'71 Pinto
Originally Posted by Haag
I already have the overview of changes for the previous year code 808 (SN00.00-P-0018C) but I cannot find the one for code 809
See attachment.
Old Aug 26, 2019 | 07:33 PM
  #66
'71 Pinto
Recall Campaign 2019080012 – 2018-2019 E-Class (213), E-Class Coupe (238), and CLS-Class (257) vehicles with rear-wheel drive, a locknut in the steering rack might have internal material cracks. In certain driving situations involving low-speed maneuvers, large lateral forces could cause the locknut to break, dealer will replace the steering rack on the affected vehicles. Total Recall Population 17.
Recall Campaign 2019080011 – 2018-2019 E-Class (213), E-Class Coupe (238), and CLS-Class (257) vehicles with rear-wheel drive, a locknut in the steering rack might have internal material cracks. In certain driving situations involving low-speed maneuvers, large lateral forces could cause the locknut to break, dealer will replace the steering rack on the affected vehicles. Total Recall Population 1284.
LI77.30-P-070145 AUG19 – 205 and 238 cabriolets produced before June 2019 damaged cords on the soft top interior trim, if damage is found on one of the cords of the soft top interior trim, always replace the cords on the left and right in pairs.
LI46.35-P-070153 AUG19 – 167, 205, 213, 238, 253, and 257 various noises can be heard when steering to the left and/or right. Acoustic behavior of the steering is subject to a certain amount of variation however, this has no effect on the functionality and reliability of the steering system. As long as the actuation noise does not significantly exceed the level of the reference steering system in bulletin video, the case will not be accepted as a complaint.
File Type: mov
File Type: mov
Old Aug 26, 2019 | 08:47 PM
  #67
rox's Avatar
rox
2018 E220d
Where can I actually find the bulletin video? Thanks in advance!
Old Aug 30, 2019 | 01:52 PM
  #68
Bimmermaniac's Avatar
2011 BMW E90 M3 ZCP Alpina Weiß, 2018 E63S4 Wagon Kallaite Grün, 2025 G550 Colorado Beige
Hello,
Anybody has access to LI07.61-P-069827? My 2018 E63S Wagon had a CEL with code P030022. They performed some software update and referenced that LI, so just curious what it is.
Thanks!
Old Aug 30, 2019 | 03:38 PM
  #69
'71 Pinto
See attachment.
File Type: pdf
Old Sep 2, 2019 | 03:24 AM
  #70
whoover's Avatar
'19 E63S sedan
See attachment.
Wow. That covers a lot of ground.
Old Oct 23, 2019 | 02:50 PM
  #71
'71 Pinto
Recall Campaign 2019090008 OCT19 – 2017-2019 213 wagon spoiler on the tailgate may not have been fastened according to current production specification might completely detach from the vehicle, dealer will check and rework. Approximately 4,765 vehicles are involved.
Old Nov 21, 2019 | 05:23 PM
  #72
'71 Pinto
Service Campaign 2019080019 NOV19 – 2012-2017 C-Class, CLS-Class, E-Class, GL-Class, GLC-Class, GLE-Class, GLK-Class, GLS-Class, M-Class, S-Class (205, 218, 207, 212, 213, 166, 253, 292, 204, 217, 222) aluminum bolts of the steering gear housing cover and the aluminum bolts on the power steering rack may corrode over time this could lead to a separation of the power steering unit from the steering rack resulting in power steering failure. Dealer will replace the aluminum bolts and seal them, or replace the power steering rack if necessary. Have dealer check VMI to determine if your VIN is involved. Approximately 398,527 vehicles are affected.
Recall Campaign 2019110004 NOV19 – 2018-2019 C-Class (205), GLC-Class (253), E-Class (213), CLS-Class (257), GT (290), G-Class (463) front seat belt buckles might not have been manufactured according to current production specification. Restraint system could be impaired. Dealer will check the relevant seat belt buckles in the affected vehicles and replace them if necessary. Customer letters will be mailed after the remedy becomes available. Approximately 29,679 vehicles affected.
Old Dec 24, 2019 | 09:28 AM
  #73
'71 Pinto
Recall Campaign 2019120008 DEC19 – 2013-2017 CLA-Class (117), GLA-Class (156), M-Class/GLE/GL/GLS-Class (166), SLK/SLC-Class (172), AMG GT-Class (190), GLK/C-Class (204), C-Class (205), E-Class Coupe/Cabrio (207), E-Class (212), S-Class Coupe/Cabrio (217), CLS-Class (218), S-Class (222), SL (231), B-Class (242), GLC-Class (253), GLE Coupe-Class (292), G-Class (463) due to a software fault in the communication module as provided by the supplier, the date and time as determined from the GPS satellite data could differ from the actual date and time starting on November 4, 2019. The correct date and time are necessary for the "Assisted-GPS" function to determine the vehicle position. Dealer will update communication module software. Approximately 24,473 vehicles affected.
Service Campaign 2019110002 DEC19 – 213 with B06 replace front left & right brake pads, disks, and calibers no further details given. Need to have dealer check VMI to see if VIN is included.
Service Campaign 2019110007 DEC19 – 2019 C-Class (205), E-Class (213), S-Class (217,222), CLS-Class (257), GT-Class (290), G-Class (463) powertrain control unit software might not meet current production specifications, dealer will update. Approximately 204 vehicle is affected.
Recall Campaign 2019120005 DEC19 – 2019 213 AMG replace driver airbag, do not meet current specifications. Not related to the on-going Takata Airbag recall. Approximately 99 vehicles affected.
Recall Campaign 2019120006 DEC19 –2019 213 AMG replace driver airbag, do not meet current specifications. Not related to the on-going Takata Airbag recall. Approximately 99 vehicles affected. Seems to be a duplicate of 2019120005 yet assigned a different reference #.
Old Dec 24, 2019 | 07:18 PM
  #74
Cerave's Avatar
E300
213 also?
Old Dec 25, 2019 | 09:14 AM
  #75
'71 Pinto
To date 213 not included reason posted 218 is in this thread.
