Bulletins 213
https://mbworld.org/forums/e-class-w...n-display.html
Service Campaign 2020080005 AUG20 – 2019-2020 213, 205, 290 software for the AMG drive unit control unit does not correspond to production configuration, dealer will update the software as necessary. Approximately 4,317 vehicles affected.
Recall Campaign 2020070004 AUG20 – 2020 213, 253, 290 vehicles equipped with rear seatbacks that can be electrically unlatched, the left rear seatback latch might not meet current production specifications, dealer will replace the left rear seatback latch. Approximately 1,351 vehicles affected.
Recall Campaign 2020070017 AUG20 – 2020 213, 205, 253 equipped with 4-cylinder gasoline engine (M264) screws that retain the turbocharger oil feed and return lines may not have been properly torqued during the assembly process, dealer will check the mounting of the turbocharger oil feed and oil return line and rework it, if necessary. Approximately 88 vehicles affected.
Recall Campaign 2020080004 AUG20 – 2017-2019 222, 213, 238, 257, 205 seat belt warning system does not meet current production specifications if the driver or passenger seat belt is not fastened, the seat belt warning would not warn the driver as intended by means of a blinking warning lamp in the instrument cluster and an audible warning tone, but only with a permanently activated warning lamp. Dealer will update the SCN coding of the instrument cluster. Approximately 56 vehicles affected.
LI46.35-P-071461 JUL20 - All models w/electric steering knocking noises when driving or steering, check wear of tie rod outer joint.
LI46.35-P-071462 JUL20 – All models w/electric steering knocking noises when driving or steering, check wear of tie rod inner joint.
Would you be able to pull the two audio files with the LI46.35-P-071461 service bulletin? I would like to confirm this TSB is applicable for the issue with my vehicle.
TIA
