E-Class (W213) 2016 - 2023
Bulletins 213
Old Oct 12, 2022 | 11:58 AM
  #126
konigstiger's Avatar
'71 Pinto
Originally Posted by murman
I asked my Canadian service manager about this recall and he said they already did this here last year.
Affected VINs were flagged in VMI as "OPEN" on June 28, 2022 according to attachment.
File Type: pdf
Old Oct 13, 2022 | 10:14 AM
  #127
murman's Avatar
S213 2020 E450 4Matic CDN Spec 07/19 build
As always, thanks K!
Old Nov 8, 2022 | 03:00 PM
  #128
'71 Pinto
Service Campaign 2022090003 OCT22 – 2021 E-Class and S-Class (213 and 223 platform) steering wheel material does not correspond to current production specifications leather may detach from the steering wheel, dealer will replace steering wheel and hand detection control unit.
Old Dec 9, 2022 | 12:53 PM
  #129
'71 Pinto
LI80.40-P-075378 NOV22 – 213, 257, 238 w/code 881 from manufacture date 4/1/21 trunk closing function inoperative, under analysis create a PTSS case to MBUSA before attempting repair on the vehicle.
Old Dec 22, 2022 | 12:49 AM
  #130
rjz2177's Avatar
Three MB's: GLK, ML & E - Class with Panam Grill
I know this is an old post but to help; others, this is called "backlight bleeding". Take Pictures of your screen and ask your SA to file a warranty claim with MBUSA to replace the head unit. This is being a known defect in US and European Models...see below post
https://mbworld.org/forums/e-class-w...n-display.html
Originally Posted by mustangn8
that’s a defective lcd panel and the entire u it must be replaced.
Old Dec 22, 2022 | 12:56 AM
  #131
rjz2177's Avatar
Originally Posted by janchee
I had this exact issue and the LCD was replaced under extended Mercedes warranty with no quibbles. The new screen feels a higher screen res. Tech did an update as well and the drivers display has a few new icons / displays.
This is technically called "Back Light Bleedings" The seal inside broke off allowing the light to bleed. No recall exist and the head unit needs to be replaced like when your iPhone screen is not black under the warranty period. see below post
Old Jan 6, 2023 | 03:58 PM
  #132
'71 Pinto
Recall Campaign 2022100009 DEC22 – 2019-2022 213, 257 12V battery in the trunk might be dislodged in the event of a crash, dealer will install additional mounting support. Approximately 19,698 vehicles affected.
Old Feb 3, 2023 | 02:37 PM
  #133
'71 Pinto
LI72.20-P-075746 JAN23 – 118, 167, 177, 206, 213, 223, 238, 243, 247, 254, 257, 293, 295, 296, 297 tailgate opens unintentionally, as of the 6th generation key can be recoded so tailgate no longer opens as a result of a long press on the button, but by double-clicking on the button instead.
Old Mar 28, 2023 | 04:04 PM
  #134
'71 Pinto
Recall Campaign 2022100005 – 2019-2022 213,238,257,167,223,290 may not meet current On Board Diagnostics (“OBD”) emissions specifications, dealer will update the software. Approximately 62,629 vehicles affected.
Old Oct 16, 2023 | 01:27 PM
  #135
murman's Avatar
Hello all. I received a warranty extension notice from MB Canada regarding "diagnostic unit leak tightness" related to my MY 2020 E450 wagon. More specifically, the Diagnostic Module Tank Leakage (DMTL) unit. Didn't even know that kind of thing was a thing!
Old Mar 21, 2024 | 11:33 AM
  #136
np6345's Avatar
'19 E300 w/ activated Multibeam
Service Campaign 2020070012 AUG20 – 2020 213 front right inner door panel does not correspond to specifications, dealer will check and rework if necessary. Approximately 77 vehicles affected.
Service Campaign 2020080005 AUG20 – 2019-2020 213, 205, 290 software for the AMG drive unit control unit does not correspond to production configuration, dealer will update the software as necessary. Approximately 4,317 vehicles affected.
Recall Campaign 2020070004 AUG20 – 2020 213, 253, 290 vehicles equipped with rear seatbacks that can be electrically unlatched, the left rear seatback latch might not meet current production specifications, dealer will replace the left rear seatback latch. Approximately 1,351 vehicles affected.
Recall Campaign 2020070017 AUG20 – 2020 213, 205, 253 equipped with 4-cylinder gasoline engine (M264) screws that retain the turbocharger oil feed and return lines may not have been properly torqued during the assembly process, dealer will check the mounting of the turbocharger oil feed and oil return line and rework it, if necessary. Approximately 88 vehicles affected.
Recall Campaign 2020080004 AUG20 – 2017-2019 222, 213, 238, 257, 205 seat belt warning system does not meet current production specifications if the driver or passenger seat belt is not fastened, the seat belt warning would not warn the driver as intended by means of a blinking warning lamp in the instrument cluster and an audible warning tone, but only with a permanently activated warning lamp. Dealer will update the SCN coding of the instrument cluster. Approximately 56 vehicles affected.
LI46.35-P-071461 JUL20 - All models w/electric steering knocking noises when driving or steering, check wear of tie rod outer joint.
LI46.35-P-071462 JUL20 – All models w/electric steering knocking noises when driving or steering, check wear of tie rod inner joint.
Konigstiger,
Would you be able to pull the two audio files with the LI46.35-P-071461 service bulletin? I would like to confirm this TSB is applicable for the issue with my vehicle.
TIA
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
