E-Class (W213) 2016 - 2023
Speedometer shot new E220d
Old Jun 12, 2016 | 09:18 AM
J.M.G.'s Avatar
'17 C63S Estate (S205) / '14 CLS 550 SB (X218) / '17 E220d (S213)
Last week, I had a chance to drive the brand new W213 E220d. The car is equipped with the new DIESEL-engine, OM654, which is a BLAST to drive! Of course it sounds like a Diesel, but it totally (!!!!) lacks vibration and drone! It is just incredible. Together with the 9g-Tronic you will even not be aware, when the car is coasting (and therefore the engine idles) and when it is applying power. It is just silky smooth!
So I went to the autobahn and went WOT!
0-152mph!
(Note: Speedometer shows km/h!
100km/h = 62mph
160km/h = 100mph
200km/h = 124mph
240km/h = 150mph)
Enjoy!
As you might notice: At around 210 a really bad wind noise starts... I hope Mercedes will deal with that!?!
Old Jun 12, 2016 | 11:20 AM
konigstiger's Avatar
'71 Pinto
Bulletin 064122 may apply: https://mbworld.org/forums/e-class-w...ml#post6807557
Old Jun 12, 2016 | 03:13 PM
thefisch's Avatar
Top Answer: 1
2011 E550 P2 4M Sedan
very cool, thanks for posting. car seemed stable all the way to top speed - as you'd expect.
Old Jun 13, 2016 | 01:00 AM
J.M.G.'s Avatar
The real difference to the W212 E-Class (which I own as an 2012 E550 4matic) is:
The car is -at least- as stable as the W212 at high speeds, however, on the other hand it turns a lot better! When entering a corner, the front axle seems to be tight to the ground. A lot less understeer. The rear turns in in a way that surprised me. At the first time I thought it would brake loose! But it does not. The W213 is extremely agile while still being high speed stable! My guess is: The electronics (ESP) help the car turning in a lot! But it works really great!
Old Jun 13, 2016 | 09:34 AM
thefisch's Avatar
Top Answer: 1
Thanks for sharing that observation. It will be interesting to see how it performs for road tests. Can't wait to test drive one myself.
Old Jun 13, 2016 | 11:27 AM
J.M.G.'s Avatar
I did a full review - unfortunately in German . Just one more note: It is pretty easy to get >50mpg even around town in this car, IF you are willing to
a) use Eco-Mode and
b) take advantage of coasting
The car is significantly more efficient than the E250 BlueTec W212 while being faster also!
