E-Class (W213) 2016 - 2023
Door Lock Pins
Old 08-21-2016, 05:35 PM
joshg1001's Avatar
2017 E300
Door Lock Pins
I noticed that on a lot of press images and those cars who are outside the US have metal door pins, while in the US, I think I noticed they are black plastic.
Can anyone confirm this, and if so, has anyone looked into ordering the silver metal pins and replacing those on their cars?
Old 08-21-2016, 06:17 PM
konigstiger's Avatar
Received 4,435 Likes on 3,152 Posts
'71 Pinto
MBUSA 09976605009051 black plastic. In addition, EPC shows aluminum 09976601002A17 + lower plastic part 0997660000 and AMG lettering 0007660800 check with dealer for availability.
Attached Thumbnails Door Lock Pins-09976601002a17.jpg   Door Lock Pins-0007660800.jpg
Yogujuhere (08-22-2016)
Old 08-22-2016, 11:56 AM
joshg1001's Avatar
2017 E300
Metal looks so much better, thanks.
Old 08-22-2016, 04:31 PM
Yogujuhere's Avatar
'14 E350 4Matic, 900WHP IS300
Wait a second. The US models come with plastic door pins?
Can you be a little more clear as to what I would need to replace them with the aluminum one like in the GLE450?
Just 4 of these? 09976605009051
(I assume you mean MBUSA 09976605009051 black plastic is the standard oem E300 door lock in plastic) can anyone confirm that the GLE450 door pin can be installed easily?
Old 08-22-2016, 04:57 PM
Vipershade's Avatar
2018 GLC63
This post might help you guys https://mbworld.org/forums/c43-amg-c...hese-look.html
It's from the AMG W205 C-Class forum, but I think the door pins are the same (the AMG GT door pins).
Old 08-22-2016, 05:04 PM
Yogujuhere's Avatar
WOW. That is a VERY slick mod =) I would definitely do this.
I assume the black plastic piece oem E class door pin is the same as in the C class. Any idea if this same mod would work in the GLE350 btw?
EDIT: (The c class post shows the plastic piece being A 099 766 00 00 which wasnt listed by konigstiger).
Dont want to order the wrong parts lol. Just double confirming I would need::
four of these A 099 766 00 00
four of these A 099 766 01 00 2A17
Old 08-22-2016, 05:37 PM
'71 Pinto
Originally Posted by Yogujuhere
Just double confirming I would need: four of these A 099 766 00 00, four of these A 099 766 01 00 2A17
Yes, total 8 pieces - revised post.
Old 08-23-2016, 09:52 AM
Yogujuhere's Avatar
Ordered. Much appreciated. Hopefully everything goes to plan.
So the stock door pins swivel out and the new ones are pressed on from what I understand. This is the same for all 4 doors ? (no change in front to rear).
Old 08-23-2016, 12:18 PM
Vipershade's Avatar
2018 GLC63
Yep, that's exactly the way the C-Class pins worked. I haven't tried the process on an E-Class (but if all goes to plan, I will be later next year). Let us know how it goes
Old 12-12-2016, 05:37 PM
Huskernks's Avatar
2017 E300 4matic - P3 Package
I got 0007660228 as the part number from my dealer. Can anyone confirm/deny this has worked with other part numbers for both front and back?
Old 12-13-2016, 06:48 PM
Huskernks's Avatar
Apparently that was the old number. They can't verify which number works for our car. Has anyone done it and can validate the install?
Old 12-14-2016, 03:42 PM
jgs1564's Avatar
2018 E400 Coupe
The aluminum door lock pins come standard on the E300 Luxury model in the US. The Sport model gets the black plastic pins. I'm going to check with my local MB dealer and see if they can order the aluminum pins for my E300 Sport.
Old 12-14-2016, 03:51 PM
Huskernks's Avatar
I checked with mine and got two different answers. Looking forward to hearing.
Old 12-14-2016, 04:00 PM
'71 Pinto
Part #s are in post 2 above: https://mbworld.org/forums/e-class-w...ml#post6894263
Old 12-14-2016, 06:55 PM
Huskernks's Avatar
Has anybody installed and confirmed the front screw and back snaps on the new model?
Old 12-20-2016, 05:35 PM
Huskernks's Avatar
All 4 doors are screw on for the W213 model. I just confirmed with install.
Old 12-22-2016, 11:34 AM
'71 Pinto
Interesting, EPC shows different.
Old 12-22-2016, 12:00 PM
Huskernks's Avatar
That is interesting. Maybe someone else will perform this on the 2017 and can comment.
I even took off one of my rear door panels before I started to confirm if it was different or not. All were threaded and able to be screwed on.
Old 12-22-2016, 12:05 PM
Vipershade's Avatar
2018 GLC63
How far do they stick out when they are locked? Can you post a picture of them locked and unlocked?
Old 12-22-2016, 12:06 PM
Huskernks's Avatar
All 4 are just like the plastic ones. It took a little tweaking with some lock tight to get them all exact. I will post pics when I am around my car.
Old 12-22-2016, 12:24 PM
Huskernks's Avatar
Old 12-22-2016, 12:40 PM
joshg1001's Avatar
2017 E300
what a great, simple mod. I am about to purchase these bc they look so good.
just to clarify, the old runs screw out, the new ones screw in?
Old 12-22-2016, 12:43 PM
Huskernks's Avatar
That is how mine worked. I unscrewed all 4 and screwed in the new ones. One on the back was able to screw down too far, so I took off the door panel to see why. The new pin wasn't being stopped by the notch they have in the door pin arm. This seems to be because the opening on the metal pin is wider than the stock pin. I used lock tight(I used blue, not red), screwed it down to where I wanted it and let it sit. Holding very tight in the right spot.
Old 12-22-2016, 12:48 PM
Huskernks's Avatar
On another note, I ordered them from this ebay seller. He ships fast and has good communication. I ordered some of the metal sport pedals from him as well. I believe it is a Benz dealer selling through ebay.
http://www.ebay.com/itm/351888141274?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old 03-13-2017, 11:13 PM
Tom T's Avatar
2017 E300
Unscrew Indeed
Unscrew confirmed. I had to use some pliers to unscrew them off. These pins are very tight on there. I got the cheap version. I get myself to pay $50 a pin.
https://www.ebay.com/itm/282359547485
I had no problem with the rear pins. The fitting are the same as the fronts. I used silicon to keep them label straight (no thread locks around).
It's ok for now.
Quick Reply: Door Lock Pins
