Snow tires for 2017 E400 luxury wagon
I prefer to keep the look of the wheels and the size of tires the same in summer and winter. I plan to buy four extra wheels for winter tires, to spare wear and tear and expense in changing over the tires twice a year. Can I simply order four more OEM wheels matching those on my car? Are those appropriate for mounting snow tires, including studded tires? If so, can someone give me the part number for those wheels? Also, I'd be very happy to have any advice on suitable snow tires, preferably studded, for the 2017 E400 luxury wagon. Are there run-flat snow tires? with studs? Michelin and Blizzak have good reputations here, so I would tend toward those if possible. If anyone knows which tires would go with this, I'd be grateful for any information, since I'll need to order them in advance.
I would recommend you stay with run flats because no spare in extreme weather can be dangerous.
We are using 225/55R17 and that is correct circumferece but I am not sure if a 17" wheel will fit a 213050
the vehicle may require 18s if you have the larger (same as E43) brakes.
Agreed though that 18 inch is a safe choice for those who are after the smallest wheel (best ride comfort).
Where are you looking?, 225/55R17 is a very common size tire and is available in several different load capacities, 97 and up
Considering the discussion about studded tyres, I agree studdless are more convenient and mostly perform equally well and perhaps at times better but the studded tyres are better (safer) when conditions are worst. It may be a rare case in our winter but for the wife's car I insist on tyres that perform best when performance is mostly needed. She can manage well in the conditions where studdless might perform better. In fact I prefer studded tyres myself too. That said, our Sprinter runs with summer front tyres, studdless winter tyres rear (it is registered as a light truck).
The E400 and the E43 share the same fixed caliper, even the C450 and the C43 use them, only difference being the AMG logo on the side.
Then there are two smaller sport brake sizes as well, plus the lux non cross drilled brakes with a single pot floating caliper.
I second Tire Rack and not needing studded tires. I am in Ottawa, which I believe is the second coldest capital city and honestly with the 4MATIC, Nokians, Blizzaks or Michelin Arctic Alpins will render your vehicle unstoppable.
My C400 had Blizzaks for 2 winters and switched to Nokian Hakkawhatever and they were a definitie improvement from an already very good winter tire.
You should be able to get a great winter setup through Tire Rack for under 2K. Nice looking wagon, I am getting one in November to replace my 2014 wagon, can't wait!
Then there are two smaller sport brake sizes as well, plus the lux non cross drilled brakes with a single pot floating caliper.[/QUOTE
The 43's use the same AMG calipers, the 400 (at least the C400) did not! The AMG and MB 4 pot calipers are (or were) different. As you, I thought it was just a label, in fact they are totally different calipers. I know, Ive had both types. Unless MB changed their 4 piston caliper in the last 2 years. The MB had square sharply cut edges the, AMG has a bulbous middle. The rotor hub, on the other hand, is the same flutted, gray painted one.
