E-Class (W213) 2016 - 2023
Dashboard vibrating
Old Aug 6, 2017 | 03:25 PM
Egonvdv's Avatar
EQE SUV AMG-line 350+
Dashboard vibrating
getting an irritating noise from dashboard vibrating.
It's the "grill inlay" on top of the dash.
wil go back to the dealer to get it fixed, but was wondering if
someone here had the same problem and knows how it was fixed?
Old Aug 6, 2017 | 03:42 PM
dbtk's Avatar
600 SWB
I had the same issue. There is an open service campaign to fix that with felt tape.
Old Aug 6, 2017 | 07:15 PM
Miho Nairoukh's Avatar
w213
can you please explain how to fix it i have same problem
Old Aug 6, 2017 | 08:29 PM
dbtk's Avatar
600 SWB
I mentioned it to my service advisor and he made an appointment to fix it. It took about 30 minutes.
Old Aug 7, 2017 | 12:42 PM
Proeliator2001's Avatar
E220d
I had same issue, took two trips to dealer before they bothered to take grill off and fix it.
My car is plaugued with rattles/creaks. Same rather useless dealer has told me they can't do anything about centre console creaking which is driving me nuts. I'm 6 for 4 and my leg rests fairly heavily against the transmission tunnel and forward edge of the centre console. It creaks and groans whilst driving along, especially cornering when my leg presses harder.
But alas, "nothing we can do" is the reply. Considering changing dealer as these guys are dreadful for this sort of thing. Good luck getting yours sorted, hopefully it's limited to just the grill which seems super easy to sort out.
Old Aug 7, 2017 | 01:18 PM
Cao Black's Avatar
2015 ML350+2025 E350
Mine separated (raised up) along the edge just in front of the steering wheel. I don't recall any vibration. RO says dealer replaced it, but might have been the felt tape repair. All good since.
Old Aug 7, 2017 | 01:47 PM
dbtk's Avatar
600 SWB
Mine was also raise (before the rapair) and now, it's less so but still slightly higher directly in front of the steering wheel than rest of the grill area.
Old Aug 17, 2024 | 05:29 AM
LarrikinAus's Avatar
E300 MY17
I know I am bringing up an old topic. I've just bought a W213 MY17 E300. It has a two year warranty OEM from Mercedes Benz as it's a Mercedes Benz certified car. It has a HUD, and it's a RHD.
I have a some rattles / vibrations in my car, and one source they have found is the rear vision mirror is faulty and they are going to replace it under warranty.
I am particularly interested in this comment because my grill is slightly higher in front of the steering wheel than the rest of the grill area, exactly as stated by you and others. See photos: https://imgur.com/a/oV5616V
What happened in the end with the grill not being flush? Based on my photos, was yours looking like that that before or after the fix that Mercedes provided in this thread https://mbworld.org/forums/e-class-w...top-cover.html. Did Mercedes ever fix it for you because its not right to have it left that way.
Clearly its a design fault given all the information in this thread and the other thread about Mercedes acknowledging the issue and putting out a fix for it so I am curious as to getting the grill back to being flush with the dashboard and the noises going away with the fix that Mercedes put out as per the link above.
This is super helpful info for my Mercedes dealer too as I can get this fixed under warranty.
