E-Class (W213) 2016 - 2023
Sensor Question
Old Dec 22, 2017 | 07:35 AM
torca2017's Avatar
2018 E400
Sensor Question
I have an E400 and I notice that when I go into the garage the sensor display comes us and as I get close to the sides the areas appear red and the car give its warning beeps. When I exit the garage the next day the display comes up and I see red sections but some days I get beeps while other days I do not. Is this supposed to happen or is there something wrong?
Old Dec 22, 2017 | 07:42 AM
ua549's Avatar
It is merely a proximity alert. A half inch spacing difference can make a difference.
Old Dec 22, 2017 | 08:20 AM
Egonvdv's Avatar
EQE SUV AMG-line 350+
i have same problem (discussed in other thread):
when reversing and turning at the same time the nose of the car
goes in the direction of a wall/car & the display goes red.
But sometimes with and sometimes without sound!
the radar is very erratic. this, plus the very faint beeping sound
of the rear radar, makes me have very little faith it in.
my w212 was much better in this respect
Old Dec 22, 2017 | 08:21 AM
Egonvdv's Avatar
this makes no sense
the display goes red, so the radar KNOWS you are close to an object. - so why doesn't it beep???
Old Dec 22, 2017 | 08:33 AM
ua549's Avatar
My experience entering my garage is that I get beeps only when the distance to the object is decreasing, not when the distance is increasing.
Old Dec 22, 2017 | 12:30 PM
The_Judge's Avatar
2018 E400 Coupe
I find the proximity display and warnings (beeping) to be consistent — as noted, it depends on how close you are to an object, such as the wall of your garage or the edge of the garage door jamb.
Old Dec 22, 2017 | 01:55 PM
torca2017's Avatar
2018 E400
Thanks. At least I know its not just me. I still think if it shows red it should beep.
Old Dec 29, 2017 | 06:44 PM
NFAREVIEW's Avatar
2018 E300
LI82.85-P-066991 AUG17 – 2017 222, 213 with COMAND (581) after resetting control unit active profile Parktronic warning segments may flash without any warning tones, update COMAND software.
Found that TSB in another thread and though it may pertain to your issue. Hope it helps.
Old Mar 6, 2018 | 07:56 AM
Egonvdv's Avatar
The problem continues.
I noticed that it's actually only at startup that the radar doesn't beep in reverse.
I takes a while for it t start working properly. Strange....
Old Mar 12, 2018 | 04:40 PM
BeachBunny's Avatar
2018 E300 Luxury - P3 and more
Do you have Warn Early selected? If so, it should beep every time. Without it, you'll see the segments illuminate first long before it starts to beep.
Old Mar 13, 2018 | 04:44 AM
Egonvdv's Avatar
yes early is selected. and it works, just not always immediately at start up
Old Apr 19, 2018 | 10:50 AM
Egonvdv's Avatar
can someone confirm to me that when display goes into RED the radar should ALWAYS beep ?
as advised in some situations (mainly when backing out) the display goes red, but no beeps.
BUT.. if I then stop the car and steer to the left or right, it does start to beep depending on wheel angle.
fyi: I've now switched off the "early feature".
Old Apr 19, 2018 | 11:35 AM
The_Judge's Avatar
2018 E400 Coupe
Mine always beeps when the indicator turns red, forward or backward.
Old Apr 19, 2018 | 12:30 PM
ua549's Avatar
There are many instances when the red warnings appear without any sound especially when entering/exiting an enclosed parking spot or approaching an obstacle.
Old Apr 19, 2018 | 01:42 PM
Egonvdv's Avatar
yes, but is this normal behaviour...? seems not...?
Old Apr 19, 2018 | 03:35 PM
ua549's Avatar
This item is on my E300 squawks list when I have the first annual service done in August.
Old Apr 19, 2018 | 03:50 PM
Egonvdv's Avatar
Car going in next Tuesday for the warped disc problem and will have them look at this too (again) + the vibrating/rattling speakers..
