E-Class (W213) 2016 - 2023
E400 Subwoofer Install
Old Jan 13, 2018 | 09:14 PM
fogozito's Avatar
E400,C200,C180,C280
hi, i have an E400 2018 and i want to add a 8" JL compact subwoofer.
can i use the rear speakers to grab the high to low conversion? and can i tap the current from the fuse box in the trunk?
*Burmerster 13 speakers ATM
Old Apr 4, 2018 | 09:44 AM
EbonyBenz's Avatar
2018 E300, 2002 G500, 2007 Porsche Cayman
I tapped into the thickest pink wires and purple wires that are going to the amp. The amp was located on the driver's rear trunk panel. tap into those with a 2 channel crossover. Always recommended to take your 12v lead directly from the battery. Buy a crossover with a blue remote wire.
Old Apr 4, 2018 | 09:46 AM
fogozito's Avatar
E400,C200,C180,C280
can you send pictures please?
Old Apr 4, 2018 | 11:49 AM
EbonyBenz's Avatar
I would, but I'd rather not take everything apart just to do that. I will be doing one for a E400 Coupe soon. Do you have a sedan or coupe?
Finished product. Amp is located in in the spare area underneath.
Old Apr 4, 2018 | 02:11 PM
Cambridgehank's Avatar
E400
Thanks for the info. I have the sedan and want to add a sub also. Is that your trunk space?
Old Apr 4, 2018 | 10:36 PM
EbonyBenz's Avatar
Yes. Depending on the subwoofer, I can build it to look completely flush. I can ship it to you, if you’re interested. Btw, the pink and purple pairs I tapped into are the front subs. You can tap into whatever you want, that was just my choice.
Old Apr 5, 2018 | 07:25 AM
E400
I couldn't tap into any wiring, even if I wanted to. I am not at all mechanical. I would need to find an installer and builder like you in the DC area. Thanks
Old Apr 5, 2018 | 09:17 AM
grossmsj's Avatar
2018 E400 4Matic
An installer is probably the way to go. There is a lot of digital signal processing (DSP) going on in the Burmester system and from the discussion I had with a local installer, it may not be straightforward what the best way to do this is. That's not to say you can't get good results different ways, but the 'best' way could be very complicated. I don't know if the base system (non Burmester) is more conventionally set up.
Old Apr 12, 2018 | 12:35 AM
runmkm's Avatar
2021 Mercedes E450 coupe
I had a 8" sub installed in the trunk, only on one side so I could fold down one side of the back seat.
I had a separate 650 watt amp to drive the sub.
The installers disabled the woofers in the front compartments and tapped into those wires.
Also had a woofer signal dial knob installed under the right side panel beneath the steering wheel, for adjusting the loudness of the woofer.
Old Apr 12, 2018 | 10:49 AM
grossmsj's Avatar
2018 E400 4Matic
runmkm,
What system was the subwoofer installed in; Base, Burmester 13 speaker, or High End Burmester?
Old Apr 12, 2018 | 03:56 PM
midwestamv8's Avatar
2018 E43 AMG || 2018 Porsche GT3
Do you mind letting me know what you paid for that?
Old Apr 13, 2018 | 05:43 PM
E400
I have been concerned about the loss of space in the trunk, if I install a sub woofer there. I need to fold down both seats occasionally. Also, why did you disable both woofers?
Old Dec 17, 2020 | 01:21 PM
colourfuze's Avatar
2018 E400 Coupe
how does it sound??
